Lt1 timing set - LS1TECH
Lt1 timing set
Thread Tools Search this Thread
Old 04-24-2012, 07:08 AM   #1
Default Lt1 timing set
im gonna put a new timing set in my 94 camaro and im deleting and plugging the water pump drive hole so a standard 350 timing set will work. im just wondering if i can get one from autozone? just tell them its for a 94 1500 truck with a 350 or what??? your thoughts??
jcraftz28 is offline   Reply With Quote
Old 04-24-2012, 07:21 AM   #2
guppymech's Avatar
'94 uses a spline drive opti driven from the cam sprocket. If you have not upgraded to a pin drive opti you are stuck with the LT1 timing set.
guppymech is offline   Reply With Quote
Old 04-24-2012, 07:23 AM   #3
No I'm not. 24x ignition. Lol
Old 04-24-2012, 08:14 AM   #4
95mysticta's Avatar
You shouldve mentioned that from the beginning that you are running the 24x setup. With the 24x setup you are limited to single row timing set unless you buy the billet tpis cover. I just finished my 24x swap and had to convert from double row to single. Many of us have upgraded to the Cloyes 9-3157 timing set with lots of success. $106 @ Summit. Thats what id recommend.
95mysticta is offline   Reply With Quote
Old 04-24-2012, 11:15 AM   #5
I can't use a standard timing set then? I was wanting something cheaper.
Old 04-24-2012, 11:22 AM   #6
95mysticta's Avatar
You can put a new stock one on but if you plan to add power i wouldnt trust it. Your call...
Old 04-24-2012, 11:39 AM   #7
guppymech's Avatar
Quote:
You laid out the coin for a 24X system and now you're going to pinch pennies on a timing set?
Old 04-24-2012, 12:28 PM   #8
I shelled out all my money on the 24x. That's why I'm going cheap. Plus I think next yr or right after I'm gonna add a blower cam to my 6psi blower. I'm a full bolton car with a power dyne supercharger. 6psi is all I want out of it too before everyone's starts talkin **** about it. I also only got $600 in the sc. Plus a local guy does all my dyno tuning. He's a great tuner too.
Old 04-24-2012, 01:52 PM   #9
95mysticta's Avatar
You want to risk 375-400rwhp through a stock timing set??? Good luck bro
Old 04-24-2012, 01:58 PM   #10
Quote:
Exactly how many stock timing sets have you seen break?
I for one have used an original timing set to make that kind of power.
The stock chain is meant to take the substantial additional load of the waterpump and is a stout piece. If someone wants to tighten it a little a $20 Cloyes S505 lower gear will do it.
I would not use a parts store one but I would feel fine with an original or replacement GM/Cloyes.
96capricemgr is offline   Reply With Quote
Old 04-24-2012, 02:02 PM   #11
warriorcustoms's Avatar
If you delete the water pump drive & have the 95 timing cover get a cloyes double roller for a factory roller block & hell since you've done away with the opti you could even run a vortec style cover & have less leakage LoL Im gonna run a Cloyes hex adjust type & still run the opti
warriorcustoms is offline   Reply With Quote
Old 04-24-2012, 09:49 PM   #12
before my opti died i only made 340whp and 360wtq. opti died the next day. go figure..
i cant run a double roller without a new timing cover. if/when i get a new cam ill gonna buy the 24x timing cover and i actually already have a comp cam double roll but i bought it before i knew it wouldnt work. i just need something that'll work till then but will also be strong/cheap..
Old 04-24-2012, 10:05 PM   #13
You only made 340rwhp with 6psi?
F0x Slaughter is offline   Reply With Quote
Old 04-25-2012, 07:43 AM   #14
Can you use the stock chain and tighten it up with the gear I listed?
Old 04-25-2012, 01:31 PM   #15
Yes fox it **** the bed. I don't know if it was the opti dying or high mileage or what.
96 cap, wouldnt that throw the timing off??
Old 04-25-2012, 01:35 PM   #16
no, it is just slightly oversized to tighten the chain.
Old 04-26-2012, 07:54 AM   #17
That makes me nervous. I don't wantta screw up the timing.
Old 04-26-2012, 08:28 AM   #18
If anything it would improve timing by taking slack out of the chain. How do you think it is going to screw it up?
Old 04-26-2012, 01:05 PM   #19
Gear ratios and all. I don't know anything about timing really other than put it back together exactly the way you found it. Lol
Old 04-26-2012, 01:52 PM   #20
Has the same number of teeth.
Related Topics
Thread Thread Starter Forum Replies Last Post
4th generation rear seats mackdaddy66 Parts Classifieds 1 10-31-2015 11:11 AM
Timing my sbc 305 Isaiah_13 Small Block & Big Block Chevy Specific 1 05-16-2014 11:02 PM
Putting in LT4 ED timing set, question Camaro350Z28 LT1-LT4 Modifications 15 05-16-2013 08:56 PM
Optispark and Timing Question OneBadTA LT1-LT4 Modifications 1 05-22-2010 12:47 PM
71 cutlass project..low 12s on a budget dre2013 Small Block & Big Block Chevy Specific 12 10-20-2009 02:58 PM
Tags
1994, 350, adjust, cloyes, dies, double, drive, inductive, lt1, motor, roller, s505, set, setting, timing, timinig, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
