7730 run a LT1? - LS1TECH
7730 run a LT1?
Thread Tools Search this Thread
Old 04-29-2012, 09:15 AM   #1
fuzzyjk's Avatar
Default 7730 run a LT1?
I purchased a complete LT1 supercharger kit. It came with a preprogramed ECU for the supercharger and larger injectors. When I opened he boxes I noticed right away that the ECU was very different. Research says it is SD and came from a 92 Camaro and that they were extensively used in the LTCC conversions. The question? Will this ECU work with the opti and what do I need to do to get it to work with my LT1?
fuzzyjk is offline   Reply With Quote
Old 04-29-2012, 06:10 PM   #2
rich5368's Avatar
Install and tune for your ECU and drop that piece o crap on ebay for $50
rich5368 is offline   Reply With Quote
Old 04-30-2012, 08:13 PM   #3
fuzzyjk's Avatar
So it will not work? The custom harness that cam with the supercharger and the ECU is pin'ed for this ECU. Anyway of working this set up?
Old 04-30-2012, 10:41 PM   #4
rich5368's Avatar
That I don't know. Gonna have to do some reading on your end. Who made the supercharger kit? Call them up and find out.
Old 05-12-2012, 09:40 PM   #5
FSTFBDY's Avatar
What car you trying to put it all in? More info needed on your end.
Im running a stock 92Z setup in my vert. but Im also running custom code for boost also. Drilled intake and MSD Pro Billet distributor. works out for me but not worth the swap if your running a lt1 setup anyways.
why not just put the SC setup on what you have and get your current setup tuned for it.
FSTFBDY is offline   Reply With Quote
Old 05-13-2012, 10:31 PM   #6
fuzzyjk's Avatar
I purchased a supercharger kit used for a 94 LT1 F-Body. It came with a hi-power coil and a custom tune. It still runs the opti. Will this older ECU be useable?
Old 05-13-2012, 10:37 PM   #7
93 Cars came SD tuned also.
whytryz28 is offline   Reply With Quote
Old 05-14-2012, 08:25 PM   #8
FSTFBDY's Avatar
Are you putting it all back in a 94 fbody?
IF it all came as a kit and was running in someones elses car. Then I would assume it will work if your putting it back in an fbody also.
Tags
10, 7730, billet, complete, conversion, converter, distributor, inch, kit, lt1, ptc, supercharger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
