Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > LT1-LT4 Modifications
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
1993-97 Gen II Small Block V8
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 05-08-2012, 11:23 PM   #1
Garage is empty, add now
lildemars09's Avatar
Trader Rating: 1
Default Excellent cam on Stock heads? need help
I am looking for the guys who run great power with their cam on stock heads, If your car is described above, please PM me or write below because i am looking to keep my stock head for now and run a nice cam that makes excellent power top and bottom. Please let me know what you have and I would like to talk to you.
Thanks
__________________
1994 Chevy Camaro Z28 350 5.7L LT-1, 3.73 gear, 48mm BBK TB, Ultra Z hood, after market MAF, Hyper tech chip, 160 stat, coolant bypass, hooker headers, 3' Electric cutout, 3200 ACC performance stall converter, Hotchkis front sway bar(Chromemoly), BMR Panhard bar, Line Lock kit, CE Subframe connectors, BMR Chromemoly strut tower brace, Aluminum Drive-Shaft, Line lock, and MSD 6AL ignition box..
In the process of installing my 58mm TB
lildemars09 is offline   Reply With Quote
Old 05-09-2012, 07:43 AM   #2
RamAir95TA's Avatar
Trader Rating: 2
Send a message via AIM to RamAir95TA
You'll probably find that the XE503 is overwhelmingly the best off-the-shelf choice for stock headed combos.
__________________
95 T/A AI 200cc stock castings, 383, Performabuilt 4L60E, Ford 9", Tuned by PCMforless 3340#,
10.81 @ 124.16, 1.43 60' Video of 10-second pass 455whp, 445tq - Dyno Vid
LT1 PARTS For Sale, MSD Opti, steam crossover tube, BMR swaybar, MAF, etc.
RamAir95TA is offline   Reply With Quote
Old 05-09-2012, 09:07 AM   #3
bufmatmuslepants's Avatar
Trader Rating: 2
You could sell the worthless hypertech, aftermarket MAF, 58 and 48mm BBK throttle bodies and get springs, a 503 and a tune with money to spare.
__________________
94 Z28 M6 hardtop power nothing, LS1 lid, ported MAF, Pacesetter LT's, ORY, bullet, dump, 7/16 1.6 Pro Mag NSA, CSR EWP, Bilstein HDs, BMR Springs, 32mm front and 23 rear sway bars, poly lcas and phb, Spohn short style TA, MSD opti, NGK TR55s, Taylor 8.2mm, B&M ripper shifter, 3.73s, Trifecta tune, LT4 KM 12.39 at 3250 race weight.
bufmatmuslepants is online now   Reply With Quote
Old 05-09-2012, 09:09 AM   #4
Trader Rating: 0
I've have the comp 502 with 1.6 roller rockers stock heads with better springs and retainers. I love it good fat power right where I use it and I don't have to spin it too hard it does run out of breath about 5900 rpm.
Rodinator1234 is offline   Reply With Quote
Old 05-09-2012, 01:08 PM   #5
Trader Rating: 1
With great power comes great responsibility.
The venerable ZZ4.
__________________
1995 Z/28, Ttops, 6sp, PowerTrain 100% bone stock....ALL OEM. 92K miles. NGK TR55@.035 gap,M1 0W-40, Leathers ala TransAm style.
Current mods:
JasonWW's UMM mod, frnt springs cut for 1in. drop, 93'rear springs w/hose, Prothane'd frnt stock arms,Koni DAsx4, 32mm Frnt sway bar&poly lnks, LS1frnt brakes, Hawk Pads, WagnerUSABLANKRotors, SLP 3ptSFCs(boltin), GdyrEagle F1's on the Stockers.(245/50)
*Next mods*:22mm rear sway bar ; Fays 2 Watts hopeful in upcoming winter.
License2Ill is offline   Reply With Quote
Old 05-09-2012, 01:51 PM   #6
Trader Rating: 1
Quote:
And run what TB? makes no sense to sell both, I don't need spare money I just don't want to dump that much in it right now all at once.
__________________
Old 05-09-2012, 02:06 PM   #7
Trader Rating: 1
This is what Lloyd Elliott recommended for my car with my set up
If you do not need to pass emissions, I would use a 228/236 .574/.571 110 LSa cam It will keep you pinned in the seat til 6300 RPM (about as high as you would wanna take a stock bottom end LT1).
If you do need to pass an emissions "sniff test), I would use a 224/230 .573/.568 112 LSA cam.
$300 shipped for a custom cam.
Looks like I might go with this custom cam
__________________
Old 05-09-2012, 02:08 PM   #8
Trader Rating: 1
Then he said I would need these as well
I sell a set of crane dbl springs, retainers, locks, shims and seals for $250 shipped that will work great.
__________________
Old 05-09-2012, 02:09 PM   #9
Trader Rating: 2
that cam above is what I used 2 years ago on a bone stock long block with stock a4 and 3.23 gear with a 3600 stall. I had the car lightened and it ran low 12s all day on motor. Then sprayed the **** out of it. The car ran very well being cam only.
SPOOLED UP is offline   Reply With Quote
Old 05-09-2012, 02:10 PM   #10
wrd1972's Avatar
Trader Rating: 12
This with stock (assuming unported) heads??? Are you sure???
Cant see it on unported stock heads but could be wrong.
__________________
1995 Z28 Convertible, M6 355ci LT1 DYNO 394 RWHP/370 RWTQ SAE thru the 9" Truetrac
Performance Mods 6" rod Mahle pistons, LE2 heads w/ Patriot xtremes, 226/232 LE cam, LE ported intake, Midwest 9" w/4.11's, K&N CAI, BBK 58MM TB, LPP Long tube headers no cats, Pro mag 1.6 RR's, Tuned by BLUECAT.Pic top down. Pic top up. Pics of my True Dual exhaust.
wrd1972 is offline   Reply With Quote
Old 05-09-2012, 02:27 PM   #11
Trader Rating: 1
Thats a sweet fukn grind.
I'd def...get the crane double springs and swap them out right there in the engine bay....don't know about the seals and such...I say skip em...and step up to roller rockers 1.7 all the way around that's gonna get that lift into the .600 territory.
What's your mileage? If its not too high..you could revisit the seals later if you rip the heads off and have them ported.
__________________
Current mods:
Old 05-09-2012, 02:27 PM   #12
1994 Pontiac Firebird
My Garage
ahritchie's Avatar
Trader Rating: 1
^There's a guy on here with a bigger cam than that (Lunati voodoo 60122 231/239) with stock heads who made 380 rwhp FWIW....
__________________
1994 Firebird Formula "The Purple car" Plum Crazy, 6spd, 383 with lots of engine and suspension mods..
1999 Firehawk Formula #37 My main DD, black, 6spd, longtubes, dyno tune, stock other than SLP options: level II suspension, hurst shifter, aurburn posi, SLP exhaust. More to come...
1967 Austin-Healey 3000 Mk III Sunny day cruiser/panty dropper
ahritchie is offline   Reply With Quote
Old 05-09-2012, 02:34 PM   #13
Trader Rating: 1
I have 125K on my camaro. I will have to ask him about that, I mean I would have to get new timing chain and such also
__________________
Old 05-09-2012, 02:36 PM   #14
Trader Rating: 1
Yea i told him what I had and this is what he recommended to me. yes my heads are unported. Well lets hope for the best.
__________________
Old 05-09-2012, 02:47 PM   #15
Trader Rating: 6
i have a LE 226/234 565/565 111lsa....very happy with it.
drives like stock with a bit of lope. i would consider it. AI makes something very very close...226/234 574/578 or something.
that is as big as you want to go with stock heads IMO.......sure you can run a cc306 but it wont really make any more power than the 226/234 and you will need to rev it to the moon.
in short, call LE or AI, they will cut you something exactly for you needs/setup.
__________________
95 z28 m6
323rwhp 338rwtq-Bolt ons, **** pass-13.1@108than
357, LE cam, Spec 2+, lid, strano suspended, 3.73, 4 inch cowl, Zo6 rims, Diet now
****** never ends**
slomarao is offline   Reply With Quote
Old 05-09-2012, 02:49 PM   #16
Trader Rating: 6
the 58m TB isnt helping you....nor would it with the cam...
once you have a GOOD set of heads you will want it than. So now the money could be put towards the cam/springs/timing chain/rockers/etc etc
also, 125k..... may not be the best idea to cam a motor like that. but its your car so........
__________________
95 z28 m6
****** never ends**
Old 05-09-2012, 03:02 PM   #17
WS Sick's Avatar
Trader Rating: 0
On another note the 58 mm T/B isnt hurting him either.
My cousin is running the Taboo GM847 on a stock bottom end, stock head LT1 (6-speed), and guess what, the car didn't melt to the ground the first time he stasrted it!!!
__________________
97 WS6 Black hardtop, lt beige leather.
Fully Forged 383 bottom end. 11.3:1 Compression, AFR 190 old style heads, custom cammotion cam (240/242@.050, .600.605 lift, 111 LS)
Performabuilt Lvl 2 tranny, 3000 PE Vigilantee, 4.10 gears.
Track times with new motor coming this spring. Old 383 went low 11s.
WS Sick is offline   Reply With Quote
Old 05-09-2012, 03:07 PM   #18
Trader Rating: 1
Thats not great but not too bad if u dont smoke when u start up then i might skip the seals. Ideally you'd get rid of the stocker water pump in favor of the electric...and run a double roller chain from gen1 sbc.
But you would have to revisit the seals prob...later when you should get them ported.
You might want to do a compression test on the cylinders to see how well your sealing before you buy a cam as 125K depending on how well it was treated could be worst or better varying from engine to engine. You'll have some info to help u make a decision then based on your wear. Remember you'll be increasing cylinder pressures.
__________________
Current mods:
Old 05-09-2012, 03:11 PM   #19
Trader Rating: 1
That cam is ILL. Kicks aftermarket asses left and right. Who'd dare accuse GM eng..of such witchly feats??
__________________
Current mods:
Old 05-09-2012, 03:41 PM   #20
94LT1TA6spd's Avatar
Trader Rating: 0
I will be looking into the Lloyd Elliot cam myself...
Thanks for posting!
__________________
Phil
1994 Trans Am
Dark Green Metallic | Leather | M6 | Stock...ish
94LT1TA6spd is offline   Reply With Quote
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
500, 60122, 94, aftermarket, cam, cat, heads, homemade, lift, ls1tech, lunati, powered, stock, toys, vbulletin, z28, zz4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
