Budget 383 dyno results! Couple issues...
#62
Village Troll
Great googly moogly.
I've only ever had three. First one was factory stock one and and was rotory related. It's now my backup. Second was rotary and sensor related and third is running good so far. Car has 130,000 miles on it.
#64
I too had a bad opti that I thought was valve float at first, however it wouldn't hurt to get the springs tested, or at least get one of these and test as many springs as you can reach:
http://www.summitracing.com/parts/mor-62390/overview/
New dual springs have over 150lb seat pressure installed Should be interesting to see how much power is picked up at 6K+ RPM! My opti is freshly rebuilt and not skipping a beat, I should be able to eliminate it as a cause for now.
#65
Can we officially call you Barney the dinosaur having the purple car?! Glad to hear everything finally got settled. There's no glory without suffering! What joy do you get out of a motor that never gave you any trouble
Now next time you blow the tires off in a cloud of smoke all the way to 60+MPH you can look back at all the headaches you went through and think what beast you made your car into
#66
The new dual springs are making it pull much stronger starting at 4K RPM+ pulling to a 6500 shift point....I still haven't found what RPM the fuel cutoff was tuned for yet by PCM for less; I'm guessing 6700-6800 rpm.
Here's a recent pic:
#67
Pardon me my good gentleman.....would you happen to possess a smidgen of Grey Poupon to entice the delicate suave faire upon a fellow friend's hors devours ?
Yeah.....TEN !!!!
How you gonna get a readin' on that that plastigage if you don't unbolt the "heavenly arranged perfect pairing.....". Take them bit***s apart and be mindful of what you're doin'. lifestyles of Rich n Famous Grand PooBah go smoke one and pull the nylons down, I say I say Pull 'dat wedgie out so your brain can get some air and save some of the same by not tootin' your own trombone. Geeeez' cuzz....
Yeah.....TEN !!!!
#68
Yeah.....TEN !!!!
Yeah.....TEN !!!!
#69
mustard ? have a beautiful day, yeah ten ?
