Manual rack and pinion opinions
Just wanted to get a feel what kit people have had good luck with. Ive seen a lot of people using flaming river. What is the best kit for a reasonable price?
None of them are what I would call "reasonable" price. They all screw you on the tiny parts. The rack is $250ish which doesn't seem too bad, then they all want $175-$200 for a bumpsteer kit (tie-rods and spacers) and then another $150ish for the column u-joint. Most of the kits are $600ish total. You shed about 5lbs total, but it is easier to steer with a dedicated manual rack over a power rack with the lines looped. Some charge extra for a brace that connects the manual rack to your stock k-member.
Must suck when you're driving on tires wider than skinnies on the street.
I'm comparing the weight difference between an aftermarket manual rack, and a stock rack with the lines looped. Neither setup will have the power steering pump and brackets. I'm not about to pay another $600 to shed 5lbs.
Im gonna either pay to have mine converted or do it myself after doing some reading. I need to bite the bullet and buy a welder. Now I'm gonna be the "guy with a truck, a trailer and a welder" fml
By far this is the best most economical way I have found
http://shop.rackdoctor.net/1993-1997...4-custom-C.htm
Just got my converted manual rack from rack doctor today. They said it would take up to four weeks and got it only in one week. I'll give another update when the car gets rolling
I HOPE they change the Steering ratio on the "Depower" rack of it won't be any better then one with the lines looped for driving.
I built my own and it still was not cheap. here is what I remember.
Rack off e-bay new $135 delivered
5/8th hiem joints $35 x2
Custom Tie Rod Sleeves $85
Pinto spline adapter $21
dirt track steering universal joint $32
18in of Double "D" rod $12
Aluminum Rack mount clamp $45
$400 spent for what I wanted to do plus custom K-member rebuild. This is what I got...
Stock joint into Double "D" rod
Double "D" rod to New Joint to Pinto spline adapter
Where "I" set my pan clearance
Tie rod sleeves to 5/8th Hiems
Modified K-member
Installed and ready
I want to say this setup was 8lbs over the stock equivalant
Modified K-member
Installed and ready
Now imagine you are the engine. with a stock rack you have to grunt harder to turn it then you would a true Manual rack
My stock rack was 2.75 turns lock to lock my new manual rack is 5
