Lt1 swap
Lt1 swap
i have a lt1 on my stand and I thinking about putting it into my 88 Monte ss. How much stuff would I have to change to make the swap, and would it be expensive todo. Everything on the Monte ss is stock. Thanks in advance for the help
I like the LT1 for cars that came with it. If you are going to the trouble of a high pressure fuel system and everything in an older car I would encourage you to jump right to the LS engines a 5.3l or 6.0l is dirt cheap and you can probably even sell the LT1 for enough to completely pay for a 5.3l.
Now if you had say NICE headers and such for the gen 1 motor those could get reused on an LT1 swap but since you said stock everything you are starting from scratch.
I have about 8k into the lt1 it put out 495 hp and 478 lbs tq in my 95 impala ss. It ran pretty good that's y I was thinking about putting it in my ss.
Did you do any of the work on the impala yourself? Or did u have it put in? Because if u did the work yourself u know there are many differences...but with some research u should get there. I would say electrical and cooling would be 2 big things that come to mind.
