1993 Heater Core Replacement
Where do you gain access to the heater core to replace it? The hoses were looped in the engine compartment and I dont know if the PO did that for leaking lines or a leaking Heater Core! I figure since they are cheap enough, I might as well replace it as preventative maintenance whether it needs changing or not.
I have read that you take it out through the Glove box opening and under the glove box so which one is it? I have read 5 pages of how easy it is just no procedure/instructions.
Joe
Joe
I'm sure I have seen removal instructions posted in the general tech section. There are only a few steps. Once you get in there, you will know where it comes out.
Thanks
