Help with opti install
Old 08-20-2012, 12:00 PM
96RamAirTA's Avatar
Default Help with opti install
Well I pulled my old opti,turned out to be an accel one I'm replacing itwith a new GM opti. So I installed it put everything back together while I was at it removed air system while I was under there along with installing underdrive pulleys. So all together now went to start it when I started back firing when turning over. So I think I installed it wrong and the timing is off. Is this correct or should I look some place else cause I'm also getting ready to install a walbro 255 fuel pump.
Here is a pic of the back sides.
Also the accel one had now rubber o rings while my new one did can it leak from not having these?
Old 08-20-2012, 12:09 PM
Badazz 97 TA's Avatar
You probably did something wrong with the install. Check that the plug wires are at the right cylinders on the opti. Cant really do much else besides you getting in there and actually looking everything over.
Old 08-20-2012, 12:15 PM
96RamAirTA's Avatar
Ya will double check that again to but I had read on another forum it was possible to install wrong
Old 08-20-2012, 12:23 PM
yeah if your a retard. lol. The cam dowel goes in the slot that is the longer rectangle looking one.
Old 08-20-2012, 02:10 PM
96RamAirTA's Avatar
Lol OK thanks for putting it so bluntly
Old 08-20-2012, 03:19 PM
CamaroRacing12's Avatar
hahahaha nice
Old 08-20-2012, 03:47 PM
jallen100's Avatar
Yeah its pretty hard to mess up an Opti install even if you have never done one before. I have heard storied of getting a bad Opti out of the box but like other said, you probably have your plug wires mixed up.
Old 08-20-2012, 06:46 PM
96RamAirTA's Avatar
So what would a bad opti do?
Old 08-20-2012, 07:46 PM
Village Troll
SS RRR's Avatar
You sure the plug wires are on the right terminals?
Old 08-20-2012, 08:53 PM
warriorcustoms's Avatar
Pretty straight forward The little titty goes on the dowel Kinda like connect the dots & the Opti is marked for plug #s Odd numbers on drivers side Even on pass side Pretty simple really Really its easier than a SBC
Old 08-20-2012, 10:09 PM
96RamAirTA's Avatar
Well I know for sure the drive side is right lol. Feels like y'all are making fun of me know huh guys its all good I'm going to look at the passenger side tomorrow ran out of light this after noon. I still think its something with the opti and not the wires.
Old 08-21-2012, 07:18 AM
shbox's Avatar
All you have to know is this to get the opti on correctly.
Old 08-21-2012, 07:37 AM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Does the GM opti have an MSD cap? Just wondering what's up with the red.
Old 08-21-2012, 09:48 AM
96RamAirTA's Avatar
Nah that's some sealant I put on it
Old 08-21-2012, 10:11 AM
bufmatmuslepants's Avatar
They are not making fun of you, just a little ribbing. Alot of the guys on here have done over 3 opti installs on their own cars in very few years, some with up to 5. Needless to say they have experience, and are bitter about the amount of $$ spent on them.
Old 08-21-2012, 10:23 AM
jallen100's Avatar
Why did you put sealant on the opti? It should have a rubber gasket underneath the cap.
Old 08-21-2012, 09:36 PM
lt1slowz28's Avatar
opti was just lined up wrong. fixed.
Old 08-21-2012, 10:38 PM
96RamAirTA's Avatar
Ya wasn't lined up right and thanks Dave for the help wish I coulda got the fuel pump done to but oh well tomorrow
Old 08-28-2012, 05:13 PM
mgsgold2's Avatar
did you get the fuel filter swapped out yet?
Old 08-30-2012, 05:37 AM
96RamAirTA's Avatar
Yea I replaced filter.
Quick Reply: Help with opti install
