Dumb question LT1
Dumb question LT1
I'm sorry but I might be gettig another camaro it's 1993 z28 I was just wondering if you can use the same heads cams an intakes for the original sbc's an also if I keep the fuel injection how to you tune these with no obdll port? Can you tune them with a timing light ?
Heads are not interchangeable without machine work.
Cams are only interchangeable from 87+ roller motors.
93s use OBDI speed density and need to have an EPROM chip burned to be tuned.
All ignition timing is controlled by the computer (ECM) so a timing light does not apply.
