spark plugs siezed, wont come out
Put your socket and rachet on it then find a good sturdy bar of some kind and put it on the handle of the rachet (the longer the bar, the better) and push or pull like hell.
Posted from LS1Tech.com App for Android
A long Breaker bar will save some bloody knuckles LoL longest one you can find Tool trucks have ratchets that are as long as breaker bars Use some PB Blaster to help work em loose Good Luck OH use some anti-seize on the new plugs!!!!
I'd use excessive force as a last resort only, try everything else first.
Try removing it with the engine hot. Aluminum expands more than steel with heat, so a hot head should loosen it up a bit. You could even spray the plug with some freeze spray. Maybe find a pipe the right size to set on the metal body only and rap it with a hammer. Let CRC or Kroil penetrant etc soak in for a day.
Something to watch out for: If you accidentally run plugs that are longer than the head is thick (never do this on purpose), the threads that stick into the chamber will tend to get fouled and be hard to remove.
Yah warm the car up then stick your hand in there and burn the **** out of yourself on the manifold or exhaust pipe. lol. You really might not wanna do that.
As ong a your not stupid bout it, i works.
Warm the car up, not up to running temp, wrap your arm in a shop towel and go to town.
You should be able to get it with wrapping your arm in a shop towel. If you aren't able to do so, they sell burn sleeves that you could use. Small price compared to messing up the head. Either way, I'd say do this and use brute force as a last resort. I'm positive it'll break loose with a cheater bar.
