need more mph in the quarter
Old 09-04-2012, 04:37 PM
unioncarpenter84's Avatar
Default need more mph in the quarter
got a 94 lt1 running drag radials with a 1.67 60ft but the quarter is 12.41 at 109 whats the easiest thing to do to get more mph..
simple mods???
Old 09-04-2012, 04:41 PM
lt1slowz28's Avatar
Old 09-04-2012, 04:44 PM
want to do it all motor its a 355 completly forged
Old 09-04-2012, 04:50 PM
96capricemgr's Avatar
Can you give us a complete rundown of the car?
Forged 355 means nothing if you put unported heads and a stock cam back on it. HP is about airflow and heads and cam are what handle that.
Old 09-04-2012, 04:53 PM
93 LT1 Vette's Avatar
Need alittle more info on your car. But the general rule of thumb is 1mph=10hp at the wheels on the big end. Big horsepower is made with good heads and cam combo's.
Old 09-04-2012, 04:54 PM
HioSSilver's Avatar
What gear you runnin? What's the weight of your car? Rpm range? What wheels/tires are on it? Stick/auto? Details.....details. I have pushed my mph up with the details and no real power added.
Old 09-04-2012, 05:01 PM
BIGCAT7274's Avatar
loss weight. it helps in all aspects of getting the car down track.
Old 09-04-2012, 05:09 PM
Lt1 350 bored to a 355
Heads ported and polished (flows: intake 278, exhaust 197)
CC Cam 230/242, .510 lift,113 lobe separation
Comp Cams Pro Magnum 1.6 roller rockers w/7/16" studs
Comp Cams 987 Dual Valve Springs
SI Silverline Series Valves,(2.00" intake and 1.97 Exhaust)
Eagle H beem connecting rods
JE Forged Nitrous Pistons
Crane Hardened Push Rods
Intake.
Ported Intake Runners to match Heads
K&N Cold Air Induction
Relocated Air Intake Temp Sensor
Exhaust
Hooker Headers Long tubes.
3" Custom Made Y Pipe
Borla 3" exhaust
Electrical
Custom Tuned Computer pcm for less
Accell Super Coil
LT1 Scanmaster
Fuel
FMS 30lbs. Injectors
Transmission
Rebuilt Stock Automatic Transo Shift Kit w/ 3 washers installed
Hayden 24,000 Tranny Cooler
Tranny Temp Gauge (In Piller Pod)
PI VIG 3500 Stall Converter
Suspension
GMS Rear Lower Control Arms
GMS Sub Frame Connectors (welded)
GMS Strut Tower Brace
Adjustable gas shocks and new coils.
10 bolt with torson locker with 4.10s
Old 09-04-2012, 05:14 PM
RamAir95TA's Avatar
I would start looking for some mechanical problems over looking for more power because with those mods you should be running far faster than 109mph.
Old 09-04-2012, 05:16 PM
tbag_skywalker's Avatar
Better tune maybe?
That's a lot of mods to only be trapping at 109. Lots of guys do that with only bolt-ons and zero weight reductions.
Old 09-04-2012, 05:17 PM
with my internals whats the time u would put on the car???
wht do u think could be wrong if anything??
Old 09-04-2012, 05:18 PM
Originally Posted by tbag_skywalker
Better tune maybe?
the guys from pcmforless tuned it they said a mail order tune would be good for it i wanted to dyno it but they said no need too
Old 09-04-2012, 05:19 PM
RamAir95TA's Avatar
Any info on the heads?
What's with the wide LS?
What's with the exhaust valves?
Have you had it on the dyno yet?
You're running what cam-only 503 cars are running so something seems to be up.
Old 09-04-2012, 05:21 PM
thts what the cam paper said and the heads are ported thts the numbers he said it was i bought it built...
Old 09-04-2012, 05:24 PM
im sorry the exhaust vavle is 1.57
Old 09-04-2012, 05:29 PM
RamAir95TA's Avatar
Dyno?
Old 09-04-2012, 05:30 PM
cam paper says gross vavle lift .510 for intake .540 exhaust
duration at .006 tappet lift intake 281 exahust 293
lope lift .3400 intake for exhaust .3600
and lobe separation 113
no dyno
what kinda time u think i could be putting down
Old 09-04-2012, 05:35 PM
RamAir95TA's Avatar
If the heads aren't butchered POS's and everything else is operating properly with good traction, reduced weight and good weather I'd imagine mid to high 11s is very doable.
Quick Reply: need more mph in the quarter
