just bought a new lt1 and just placed a big order
hey guys i just bought a 1995 firebird with a brand new lt1 engine. Motor is bored 20 over and i just ordered a lot of stuff for the car trying to get estimates on what my horse power might be and some recommendations on what else i should get along with what iv already ordered .......
So far i have ordered
Edelbrock 61909 aluminum heads
XFI" 280 Hydraulic Roller Camshaft
Edelbrock aluminum Roller rockers
Pacesetter longtubes 3"
pacesetter off road Y pipe 3"
Edelbrock 3.5'' cold air intake
Trickflow 58mm intake manifold
Edelbrock 58mm throttle body
36 pound fuel injectors and upgraded rail
And 4.10 gears
What you guys think
And 4.10 gears
What you guys think
Better cancel that order and get a real build going... at a minimum call lloyd Elliott or advanced induction for your heads cam and intake. The ones you posted aren't worth the trouble imho
hmm everything i ordered was very highly talked about by them and were said to be good parts and i wouldnt have any issues but they made some recommendations but just trying to get my business i was assuming
Of course they are going to talk you up... whoever was selling it just wanted your money.. hard earned cash spent on aside from the cam nothing more than an after market stock replacement.
If you're just doing the top end, skip the intake manifold (I don't think trickflow makes an LT1 intake manifold btw) But you may want to consider having it port matched by either Ai or LE when you have your heads done.
Like others have said, Have Elliot portworks or Advanced Inductions port your stock heads, they'll make more power than standard aftermarket castings for the most part, and are cheaper.
The Pacesetter Headers and Y pipe are a great choice, however. But I think they are usually the cheapest over at Texas Speed & Performance's website. Check them out.
Also, what fuel rail did you order? I haven't seen "upgraded" ones for an LT1 before? I think guys running 400-500hp are usually just running the stock fuel rails.
The reason i changed my mind so fast is its my first car build and i made my choices based off a couple of buddys different builds, and they try to know what there talking about but always dnt... i have no clue what to go with im in a learning process and just wanna make the best bang for under 4 grand but i spoke with lloyd Elliott for 45 min and cleared up a lot of things for me so im ganna have him do up my heads with the LE 2 package and a custom cam and hes ganna port my intake for me as well...... Im still going with the 58mm throttle body and 36 pound injectors, longtubes and the cold air intake. then i hear in ganna need a pretty serious PCM tune
