Replacing voltages regulator
Old 09-20-2012, 09:02 PM
kylemm1002's Avatar
Default Replacing voltages regulator
I'm having a problem of fluctuating voltage on my 95. I relocated the alternator when I deleted the ac. Replaced the big 3 and cleaned all grounds.
I'm thinking of throwing a brush set and voltage regulaor in to see if that helps. I saw the youtube vid on rebuilding re cs144 but I can't tell...is the voltage regulaor soldered to the brush holder assembly? Or just bolted to it?
Thanks!
Old 09-21-2012, 07:52 AM
sleeperLT1Z28's Avatar
It's soldered, but it's pretty easy to heat it up and disconnect the parts. I replaced the regulator and brush set in my Autozone 'rebuilt' alternator, and it solved my voltage fluctuation issue.
Quick Reply: Replacing voltages regulator
