Need a tachometer/shift. What do you guys recommend?
Old 10-01-2012, 09:35 AM
Rob94hawk's Avatar
Default Need a tachometer/shift. What do you guys recommend?
Need a tachometer/shift light. Just saw a guy in a lowered TA in St. James with a HUGE one on his dash but that's a bit overkill. Maybe one to replace on of the center vents? What do you guys recommend?
Would one of these fit in the circular vents? Maybe a pillarpod?
http://www.autometer.com/dpss/index.html
http://www.autometer.com/cat_gaugede...id=3627&sid=15
Old 10-01-2012, 09:45 AM
FAD2BLK93's Avatar
I have used that tach before, had to send it back for a refund. It had electrical issues. Not saying its a bad tach, just mine had problems. I now run the MSD tach, and i love it.
Old 10-01-2012, 10:02 AM
guppymech's Avatar
I have a Autometer 5340 pill style shift light mounted to the steering column. It lines up directly in line with the center of the tach and doesn't block anything (well except for the left turn signal blinker). Shift lights work Fantastic, one of the best additions to the car. The only thing I use the stock tach for lower rpms. Check out this thread for more info and how I wired mine up.https://ls1tech.com/forums/lt1-lt4-m...estions-2.html
Old 10-01-2012, 11:53 AM
quik95lt1's Avatar
my buddy runs that tach in his 403 01 SS......cool piece light works good......shouldn't need it to shift the car though
Old 10-01-2012, 12:09 PM
Village Troll
SS RRR's Avatar
If shifting under 7K why not use the stock tach and a shift light? Even though the tach may not be spot on the shift light will.
Old 10-01-2012, 12:16 PM
Carter01's Avatar
Raptor Shift light gets my vote. However i like the stock look on my cars.
Quick Reply: Need a tachometer/shift. What do you guys recommend?
