Having some serious tram lining issues
I've been having a problem with the contour of the road pulling my car one way or another for about a month now, had her up on the racks to check out everything in the front end, bushings, ball joints, sway bar links, ect...
Everything seems okay but it's seemingly getting worse and has me a little concerned.
I'm kinda hoping someone will bring something to my attention that I may have passed up
Eagle aloy polished alum. 16's
Not sure the tire size, I'd have to check
Back tires are about 80%
Fronts are mismatched with 25-30%
And I run em at about 32psi, any lower in the front and I get a wobble which I'm sure is due to the front tires being out of balance
This could very well be the issue.. Though it seems almost too drastic to be the tires
Either way, I havnt tried rotating front to back yet souly because I had a pretty knowledgable friend of mine tell me tht putting mismatch tires with uneven tread wear on a posi rear will cause damage
Is he right?
Is he right?
it will be fine, but mix matching different brands and makes of tires isn't really helping your issue. Pony up for some decent tires, it makes a world of difference.
I plan on buying tires next season, but for now I'm saving up some cash for a winter beater so untill then I'd like to just rotate tires, the backs are a matched set
You can potentially do damage to the rear with different tires on the rear. Will it happen to you, nobody knows. It depends on how mismatched the tires are, the way you drive and the mileage you drive.
From the description of your tires they are most likely causing the steering issue. Yes it will continue to get worse, likely at an increasing rate.
The only solutions you have are to get new tires, stop driving it, or deal with it and know it's going to get worse.
Maybe I'll just find a decent set of matched used tires to throw up front, I jacked the front end up today and gave the passenger side a spin.. Tires a little out of round, possibly a broken cord or something
Deffinately my issue though as it seems any rut on the passenger side almost causes an off road excursion
Nope, though its not tracking either way in the rear nor is it a consistent pull to one direction..
I'm pretty sure it's this one tire and now that I think back, I'm pretty sure I can narrow it down to exactly when the problem started...
Ran over a paver brick about a month or so ago and started noticing a little wobble after that
