I dont understand how to remove the knock sensors.
I see the connector but I don't understand how to remove it or the sensor to drain the cooling system. Also what is the best way to flush the system with water just run a hose to where the radiator cap goes while the car is running?
to remove the knock sensor use a good pair of needle nose pliers (carefully) on the sides. it is a squeeze type connector on them. squeeze and pull.
Its an oval connector, so squeeze on the widest part of connector. if that helps
Super Moderator
This is LS1 tech, not LT1 tech....no ne knows what kind of car or engine you have if you don't tell them. Stop posting your LT1 questions in this section. This is the second time I have had to move your post to the correct section. Next time there will be consequences.
