crank case pressure
do you have breather on each valve cover....probably not getting rid of enough of the pressure if it is pushing dip stick out. I am having issue also and gonna add another breather, but before I figured it out I blew my front and rear seals out......... come to find out. Its not bad to where I loose alot of oil but dont like the fact less than 5k on new motor and a oil leak.
is it a new motor or a new build? did it ever ping or anything. When I was stock and if it pinged I had broked piston lands and it would push the dipstick out.
Never a ping or oil leak until he started boosting now there's a oil leak. 150xxx on bottom end 500 miles on all fresh gaskets 80 miles on turbo looks to be coming out of turbo as well as the dip stick
Badhawk does the GZ Motorsports pump for our cars fit where the alt should go? I need one as well but I have the SpeedInc accessory drive kit and my alt is relocated to drivers side lower and has an idler where the alt used to be. If the GZ would bolt in place where the alt used to be it would be perfect. Also doe the GZ pump work with the factory serpentine belt?
