lt1 coil -- which side is positive and negative
There really is not a positive and negative side according to the schematic. Both of those leads are tied to positive voltage. Perhaps the bigger question is why you are asking?
The pink/black and white/black with both have voltage on them when viewed from the ICM connector (goes to A and D terminals on the ICM).
OP, doesn't Crane have an LT1 specific (2 connector coil) wiring diagram?
The pink strips indicate switched 12v.the white is the grounding part of the coil system which causes the coil to discharge the voltage. so yes to answer your question. Pink stripes/positive and white/negative. I referred from the msd installation instructions for the gm dual connector coil.
http://www.msdignition.com/uploadedF...uctions(1).pdf
Page 14
Page 14
I figured one of the manufacturers would have the info. I was just saying that using a meter to look at voltage was not going to tell him which was which.
Page 14
Page 14
