I love my car, but.....
Old 10-31-2012, 07:51 PM
Jeffywood's Avatar
Default I love my car, but.....
....its driving me insane! Not really, I just want it to be done already. Ok here's the problem, burned a plug wire, but with the pace setter headers it was easy to replace. Ran everything correctly AND whlie I was in there I changed out my stock elbow, for a trickflow aluminum elbow to my 58mm tb. Its got a cold air kit on it already, but now it backfires and shakes something fierce. Found a broken O2 sensor wire, and am in the process of replacing the O2 sensor, my question is if this doesn't work, could I have fouled the plug or do I need to re-tune the whole setup together??? Any help is greatly appreciated and after this I'm starting on my suspension.......
Old 10-31-2012, 08:18 PM
93 LT1 Vette's Avatar
So the car was running good. You burnt a spark plug wire on the header. You changed the wire and now it runs like crap?
Old 10-31-2012, 08:44 PM
fergymoto's Avatar
Sounds like you have the firing order wrong or have a cylinder or more than one cylinder not firing. Just look it over again and you will likely find something along those lines.
Old 11-01-2012, 03:48 AM
Jeffywood's Avatar
Yessir. Thats exactly how it went.
Jeffywood's Avatar
Going back under it in the morning, after I get a few hours of sleep.
Old 11-01-2012, 03:57 AM
stangkiller2005's Avatar
im assuming this is an lt1.
my money says you either crossed a wire, your opti took a poop, or your fuel pump took a poop. leaning more towards the first two options.
Old 11-01-2012, 05:09 AM
RamAir95TA's Avatar
I agree with the first two posters. Probably something in the plug wires, perhaps the boot isn't completely seated on the plug (happens more often than you might think).
Old 11-01-2012, 07:07 AM
96capricemgr's Avatar
So is this a basically stock car you put a Trickflow elbow and 58mm TB on?
Signatures help us help you.
Old 11-01-2012, 09:38 AM
djjab57's Avatar
did you check thee rest of them
Old 11-01-2012, 02:53 PM
Jeffywood's Avatar
LT1, bored .030 over, Comp Cam, Pacesetter Long Tubes w/ ORY- pipe, Cats and EGR deleted, Magnaflow exhaust note. MSD ignition module, 58mm throttle body, cold air intake, Gasket mapped heads, Ported intake. B-cool radiator...
Old 11-01-2012, 02:59 PM
Jeffywood's Avatar
I forgot, 2300 stall, stage 1 shift kit, magna flow exhaust with mandrel bent tubes from headers to the back.
Old 11-01-2012, 03:01 PM
Jeffywood's Avatar
Cool, going back under it, I replaced the fuel pump (twice, first one crapped out) a few months back, its got pressure. And the opti was done this year, I really hope I didnt burn it up.
Quick Reply: I love my car, but.....
