Felpro gasket on aftermarket headers
Old 11-01-2012, 08:06 PM
trilkb's Avatar
Default Felpro gasket on aftermarket headers
Will the ms 95585 gasket work on jethot long tube headers? Ive searched and am getting mixed results. Some people said the "1406" gasket works and the ms 95585 doesnt...some say they both work...you get the picture.
Also can you double up header/exhaust gaskets? Not that I am going to do it, but the guy at the parts store said you could and It kind of threw me.
Old 11-01-2012, 09:06 PM
02v8ta's Avatar
I would have just left haha... No don't do that, and go tell him that.
That's what I'm putting on for my header install soon. You should be fine.
Old 11-01-2012, 09:13 PM
Blue85350's Avatar
running 1406's on mine, haven't had a problem yet.
Old 11-01-2012, 09:22 PM
fex77k's Avatar
The only ones I doubled have metal on one side(they have three individual gaskets per side), you put them on so the metal is facing the head and the exhaust. They won't stick if you have to remove the header. I haven't had much luck with most gaskets, with mr gasket being the absolute worst.
Old 11-02-2012, 04:47 AM
RamAir95TA's Avatar
IMO doubling up gaskets increases the chance of a leak because now you've doubled the surface area of the sealing faces (by putting two gaskets together the middle "seam" is a potential leak point).
Not to mention you've reduced the thread engagement of the header bolts (unless you use a slightly longer bolt).
Old 11-02-2012, 06:07 AM
bowtienut's Avatar
From my experience, the thicker the gasket, the sooner it will fail and the bigger the leak.
I've done best using the stock stamped steel shims that are OEM with the manifolds. If your surfaces aren't flat enough to seal with them, or if your header flanges are too thin and distort, then you'll have problems no matter what gasket you use.
Old 11-02-2012, 08:38 AM
Mystery Bird's Avatar
1406 on my Hookers, same as Jethots.
Old 11-02-2012, 09:26 AM
fex77k's Avatar
I use a longer arp bolt now. Since i built my own headers i run a 1 piece gasket.
Old 11-03-2012, 09:58 PM
trilkb's Avatar
Well I had already bought the MS95585's which is why I was trying to get info on them over the 1406's.
Might try to throw it on tomorrow, might say f-it.
Quick Reply: Felpro gasket on aftermarket headers
