96 trans in 94 ?
Old 11-03-2012, 08:35 PM
saylorZ28's Avatar
Exclamation 96 trans in 94 ?
i did a search and seen that you can put the 96-97 trans in a 94 but not a 94 in a 96-97 and it work right.. question is if i put the 96-97 trans in a 94 only thing is the lock up wont work is this correct? reason i ask budie of mine has need of one and if it will work i told him he could have mine to help him out .. any ehlp would be appreciated.
Old 11-04-2012, 05:21 PM
saylorZ28's Avatar
dang no info only thing i cant find is that the tcc wont work but it says that it will work. only thing is the lock upwont occur.. it didnt sy anything about swapping seloniods or anything. he needs his car and i cant help him with my trans unless i know .. cause its a good trans i wont give it to him if it will screw it up
Old 11-04-2012, 06:30 PM
96capricemgr's Avatar
I can't directly answer your question but maybe it will help to know the difference is that 95+ have Pulse Width Modulation PWM I know the earlier tranny does not support this.
I would reresearch this with the PWM idea in mind.
Quick Reply: 96 trans in 94 ?
