LT1 WS6 Air intake Block-Off Plate?
Old 11-12-2012, 12:47 AM
MasterTomos's Avatar
Default LT1 WS6 Air intake Block-Off Plate?
I recently switched over to a ram air setup on my '95. The area where my original airbox was is now just an open hole in the engine bay. I planned on just leaving it that way, but I saw on here the other day that GM and SLP used to make a "block off plate" for the hole on ram air cars.
So I've got a couple questions:
1). Did this come on all LT1 WS6's and Firehawks?
2). Did these come on 96-97 SS cars?
3). Do LS1 cars have these, or were they just made solid in that area?
4). Where the hell can I get one?
Thanks!
Old 11-12-2012, 02:08 AM
94 White T/A's Avatar
Sorry if it sounds rude, but what is the problem with leaving the stock location open? Do you just want it covered?
Old 11-12-2012, 06:59 AM
RamAir95TA's Avatar
I am confused on where you're talking about an "open area."
Old 11-12-2012, 07:12 AM
Village Troll
SS RRR's Avatar
I believe it is the hole in the inner fender where the stock filter was located and where the CAI connected.
SLP did indeed make a plate for that, but you'll be hard pressed to find one. Probably best to make your own out of a sheet of aluminum, or do a google search and see if anything comes up.
Old 11-12-2012, 11:38 AM
Rob
Rob's Avatar
I don't remember seeing a plate in my car. There is a plastic scoop riveted to the metal though. I just thought it was the original intake piece? Never really looked at it closely though.
Old 11-12-2012, 06:15 PM
Spartan7's Avatar
98-02 cars have their fuse blocks there.
Old 11-12-2012, 06:43 PM
94FBIRD's Avatar
I have the SLP block-off plate. I bought years ago on a clearance sale. I mount an MSD ignition box on it. It is just a simple piece of rigid plastic. You could cut your own out of plastic or sheet aluminum and mount it with a few sheetmetal screws.
Old 11-12-2012, 08:07 PM
1961ba427's Avatar
My 97 SS has a plain plastic block off there. The wrecked 97 WS6 that I got for the parts for my Formula has the same except it has what I guess is the headlamp module (or something) attached to the top of it.
Old 11-13-2012, 06:05 PM
1995blacktattop's Avatar
or dbl sided tape for that matter. thats what i got with mine when i ordered it from GM
FWIW here's a good pic of that blockoff plate installed as well as what it looks like without the plate. i beleive SLP still sells it but GM probably discontinued it years ago (got mine in early 08)
Old 11-14-2012, 12:16 PM
There is no real functional issue with it being open, other than the cosmetics. I'd like one off a WS6 so I can mount my headlight box their, as it's currently zip-tied (normally attached to the stock airbox-which is gone now obviously) and it just bugs me.
Old 11-14-2012, 04:31 PM
WS Sick's Avatar
I have no idea where you would get one, I have a hard time getting just regular replacement body and trim parts new from the dealers I have tried. Mine is as mentioned above a plate there with the light module popped to it.
Old 11-14-2012, 04:39 PM
warriorcustoms's Avatar
Youll just have to use some card board to cut & fit Then tranfer to plastic or thin aluminium Im gonna do mine because I wanna tuck & hide all the wiring I can Since Im restorin the damn car & buildin a 396 with nitrous ,4L80E & S60
Old 11-14-2012, 11:34 PM
SLP still has it on their website for $14.95. i was expecting one that clipped in like an OEM i sae once but apparently by 2008 GM was only selling ones that were taped in. i actually got a roll of dbl sided trim tape with the blockoff plate i used it to attatch the plate to the car and the headlight module to the plate. my jaw about hit the floor when he quoted me $43 for it, but for some reason when i picked it up i didn't look at the total very closely and saw it some time later and it was only $20. not so bad, lol.
Old 11-15-2012, 10:36 AM
I did find it on SLP's website and ordered it last night for $14.95. OF course they have the $25 minimum, so I had to order up some valve stem caps and a hat patch too (lol).
Hawk's Third Gen did have one, but they wanted $35 for a used one plus shipping.
I'm interested to see if I get double sided tape, or a bolt, or clips, ect with the new SLP one.
Old 11-15-2012, 10:49 AM
djjab57's Avatar
I use the SLP one and it uses double sided tape
Old 01-22-2013, 08:26 PM
1961ba427's Avatar
SLP Online Part # 210280430 in case anyone else has problems finding this.
Old 01-22-2013, 11:07 PM
speed_demon24's Avatar
Thanks, just ordered it from sdpc.
Old 01-23-2013, 02:51 AM
What did you pay through SCDP?
Old 01-23-2013, 04:12 PM
Around 23 shipped. I just googled the part #.
Quick Reply: LT1 WS6 Air intake Block-Off Plate?
