which plug wires are sugjested to use with headers?
Old 11-25-2012, 10:18 PM
czechnuts's Avatar
Default which plug wires are sugjested to use with headers?
Pretty self explanatory. Mine are not bad.......but I'd rather not torch my wire's. So just some build my owns or what? Thanks.
Old 11-26-2012, 05:48 PM
Mike.'s Avatar
I use msd over the valve cover wires. Everything else I tried eventually got burnt.
You can order the kit and assemble them yourselves, or find someone that charges a bit extra and get them put together.
Old 11-26-2012, 06:04 PM
Z28Camaro30Ann's Avatar
I use MSD Over the Valve Cover Wires as well...Made-4-U makes a great kit to do this easily, just look for the OTVC Kit, then find someone who sells the custom length SP Wires that work for an OTVC kit. I have had this for 3 years with no burned plug wires, and I think it looks great
Old 11-26-2012, 07:19 PM
02v8ta's Avatar
I never had an issue using stock wiring routed the stock way with a ziptied wire here or there Or just use OTVC wires for them to really be out of the way.
Old 11-26-2012, 09:13 PM
Spartan7's Avatar
Same here, stock length wires zip tied close to the block. I got tired of OTVC and went back to stock routing.
Old 11-26-2012, 10:22 PM
czechnuts's Avatar
Thanks. Being since I don't want to run into the issue of F'n my self and gettin stuck. Which bolts do you guess run for your headers? I'm having an issue finding them for our engines. Or is it the same for sbc's?
Old 11-26-2012, 10:45 PM
Mike.'s Avatar
I use stage 8 locking fasteners. I kept replacing gaskets with the stock stuff.
3/8 X 16
3/4 length if I remember right.
Old 11-26-2012, 11:21 PM
czechnuts's Avatar
Yeah I don't intend to run stock. I'm lookin at arp. But being kind of a pain to figure out which are just for these LT1's or sbc in general.
Old 11-27-2012, 05:27 AM
nascarnate326's Avatar
IMO use the cheap wires. I have the autozone specials and they have been great. Mine are routed up and over the headers.
Old 11-27-2012, 06:12 AM
RamAir95TA's Avatar
I also got tired of using OTVC wires. There are more drawbacks than advantages, IMO.
Don't use a 3/4" bolt - use a 1" stainless 12-pt 5/16" head 3/8"x16 bolt. The longer the bolt the more thread engagement and the more resistance to backing out. Use a dab of anti-seize compound to help prevent the threads from galling.
Old 11-27-2012, 06:27 AM
Lizard King's Avatar
I got my locking header bolts from a sponsor http://www.ws6project.com/user_stor/...inless-steel-/
No problems so far, 10k miles since header install. As for wires, I just use the MSD 8.5mm ones with zip ties.
Old 11-27-2012, 07:53 AM
czechnuts's Avatar
Yeah the flange on the ps LT 's are pretty thick. Also the msd's are what I'm running now. Hate to trash them. Any suggestions on what to zip to?
Old 11-27-2012, 01:44 PM
Big Al's Avatar
Had MSD wires on mine and they were arcing where the wire is crimped to the terminal that clips on the plug. Found it with an ignition scope. I removed all the boots and about half of them were crimped incorrectly. Bought a cheap set of Taylor wires and tied them out of the way. Over the top on 1 and 3 the rest under. No problems so far. Just make damned sure they can't get to the headers.
A 95 Z28 long tube Pacesetters, MSD 6AL, MSD coil.
Old 11-27-2012, 03:10 PM
guppymech's Avatar
I swapped plug wires for #6 and #7 cylinders when going from manifolds to headers. With the angle plugs I needed to route the 90 deg plug boots for 6 and 5 aft away from the header tubes. Stock routing cyl 7 goes aft then fwd-don't need to route it that way with headers. I use Adel clamps bolted to the holes in the block for the stock plug wire raceway to keep the wires away from the headers. Stainless 1 inch long header bolts are nice since they won't rust. Picture is of the Adel clamp, you can get them at Aircraftspruce.com or something similar at your local hardware store.
Old 11-27-2012, 03:40 PM
speed_demon24's Avatar
Firecore, my MSD's were arcing pretty bad. And locking header bolts are a gimmick. If OEM's cam keep the bolts tight for the lift of the car there's no reason you can't. I've been running arp's for years and check them every year or so and not once has there been a loose bolt.
Old 11-28-2012, 12:15 AM
czechnuts's Avatar
I want to run all ARP. But I need to know if any are LT1 only. Lol But that keeps gettin passed over! Lol can anyone help me here?
Old 11-28-2012, 12:37 AM
fex77k's Avatar
I ran ARP 400-1209 header bolts on some pacesetter longtubes. It is a 1 inch bolt with 5/16 head so you can use a small box wrench on them with no problem. I just put anti seize on them and check them after the first few heat cycles.
As for routing the wires I have fiberglass boots on everything and tried to run it close to the stock locations.
Old 11-28-2012, 12:49 AM
guppymech's Avatar
Any header bolt for a SBC will work. The bolts in my pic above are ARP 400-1111, 1.00 long 3/8 head stainless bolts.
Old 11-28-2012, 08:53 AM
czechnuts's Avatar
What about manifold, head, main, etc? Are any of them just sbc? Just u went to price **** out and summit wasn't very specific. Plus some part store people amaze me. Figure this would be a good start.
Old 11-28-2012, 09:05 AM
Village Troll
SS RRR's Avatar
Originally Posted by speed_demon24
Firecore
Should not endorse a company who states they will never do LT1 plug wires again.
Quick Reply: which plug wires are sugjested to use with headers?
