Hyper or forged pistons? N/A high compression E85
I've got 6" Scat ProComp rods, Forged Scat 3.75 crank, but trying to decide on pistons. I need the smallest volume possible for max compression. I have heard that hypers offer lighter weight and tighter clearances, which is what I will need for a 13.5-14 cr E85 N/A engine. Any reason not to go hyper?
The lowest quality forged piston is still better than the highest quality hyperutectic piston.. I may be going too far on this however it is what I have seen. The factory Lt1 pistons are hyperutectic and are decent especially compared to aftermarket hyper slugs.
Build a shortblock thinking about the future instal good quality parts built for longivity and you will have a very good foundation for many different combinations.....
I think your question has already been answered but running hypers with that kind of compression is a little risky. A poorly made hypereutectic piston can develop a crack pretty easily. The higher silicon content makes the harder, but also more brittle.
I agree with above statements set your self up for the future! The fact that you're willing to run that aggressive of CR tells me you will push this motor to the edge so why not a lil more insurance!!
Ok, then what are some decent light forged pistons that won't break the bank? I can't seem to find weights on Summit. This is an autox/RR car, and also weekend fun-car, so I want it to be fast revving and last as well.
IMO when building an engine I would jump right from stock to Mahle Powerpak/equivalent or better.
The Powerpak being 4032 instead of 2618 uses a tighter bore clearance for less noise and will handle "high mileage" better. My understanding is 2618 will wear out the ring grooves faster than a hypereutetic or 4032 piston.
When you look at features, weight, what is included the Mahle are not cheap but they are a good value and really that is what most of us should look for in a build. "cheap" nearly always cost more in the long run.
Forged.
Wow - I guess the Mayan calendar prophecies are correct and the world IS indeed coming to an end in a few short days, because I actually AGREE with "96capricemgr" and (adding to this Armageddon-like dilemma) he did NOT suggest that the OP use the stock parts!
I guess it's time for me to re-read the book of Daniel!
That is a good deal. Unfortunately, I'm not buying until the beginning of the year due to Xmas, but I want to have all of my parts list ready to go, and pistons and rings are the only parts I haven't decided on yet. Which makes me ask, which rings would be best for a high CR E85 setup? Total seal, others?
