hopefully my last 24x question about repin
Old 01-09-2013, 05:48 PM
daddyoisback's Avatar
Default hopefully my last 24x question about repin
went threw harness a second time rechecked every wire. Need to know where these two go.
ls1 red 9 fuel pump relay control:chart says fuel pump relay
ls1 red 10 engine speed output:chart says tachometer
I'm using efi's chart and 2000 pcm and 97 harness
Old 01-10-2013, 04:55 AM
S10Wildside's Avatar
LS1 RED 9 fuel pump goes to connector C220 cavity J.
LS1 RED 10 tach output goes to connector C230 cavity D.
The GM schematics would help in this situation.
Old 01-10-2013, 05:13 PM
what I have from searching is for my 2002
c220 J is starter enable relay(vats)
c230 D is uart serial data primary(v6)
Ok did some more google'n found out what my problem is. the year of my car!!!!
97' LTx c230 D is tacometer signal to instrument cluster
and c220 J is fuel pump relay control
Now I have to figure out what the hell I'ma do now.....ugh
Thanks Mike for your help.
Quick Reply: hopefully my last 24x question about repin
