LT1, heater core flushed and still no heat.
Old 01-19-2013, 03:14 PM
nitroheadz28's Avatar
Default LT1, heater core flushed and still no heat.
I'm sure a bunch of you have seen my opti thread, well today I got the system filled and bled. I idled the car for around an hour and the temp settled at about 170-180* (I have a 160* t-stat), I had the heat set to max with the fan on high while bleeding it.
The air is barely lukewarm though, what else could it be? I blasted the lines with a garden hose until I got water coming out of the opposite line- what gives?
Also my car idles at about 850-900, any common areas for vacuum leaks/ a good way to test? I think I read that stock should be 650, then again the po had a pcmsforless tune in so who knows what its set at.
Thanks.
Old 01-19-2013, 03:36 PM
RamAir95TA's Avatar
180 degrees may not be warm enough. Remember these cars have were designed to run at 220 degrees. My car has the same problem. It runs at 170-180 and the heat is only lukewarm.
Old 01-19-2013, 03:42 PM
djjab57's Avatar
Mine to and we have had a few cold days here in the Houston area. I need to put my 180 back in
Old 01-19-2013, 04:07 PM
trilkb's Avatar
Every 160º t-stat ive had in a fbody had no heat, not even luke warm. I would get a stock one in there
Old 01-19-2013, 04:48 PM
I just got back from a shakedown with 25 hard miles on her, temps dipped down to about 40/ high 30s and the air was straight up cold.
Personally I've never seen the sense of running a 160* t-stat, isn't the car burning more gas than it should?
Thanks gents
PS- Today was my first time driving in under 45* temps and with bald Sumi's in the rear, WOW what a wild ride.
Old 01-19-2013, 05:10 PM
02v8ta's Avatar
On my 97 AFTER I replaced the heater core with a brand new one I had normal, hot heat from my vents. That was with a 160 stat and tune for it. I think these old heater cores are fairly clogged and people like to say its the tstat.
Just my experience with one of my fbodys.
Old 01-19-2013, 05:25 PM
02v8ta's Avatar
Also OP when I did the flush on mine I had heat for a day then it faded again. Core was to far gone and that'd be my guess with yours as well.
Old 01-19-2013, 05:35 PM
shbox's Avatar
Did you flush it both ways? Might not help if the core has many passages clogged, but it should be done both ways to make sure you did all you could. Also, did you flush the hoses and not just the core at the firewall?
Old 01-19-2013, 06:05 PM
toomany's Avatar
My car has a 160* t-stat and correct tuning for it. It can sit and idle all day long when the outside temps are 40's and bellow and only put out sort of warm air. Need to drive it around some for it to get any real heat going. Even then if you stop and idle for a while it will cool back off. FWIW, I flushed my heater core when I had the motor out. No idea how the heat was before as I pulled the motor after putting maybe 2 miles on it.
Old 01-19-2013, 06:08 PM
02v8ta's Avatar
Also no idea how old that heater core is? Kinda supports my argument they're all just mildly clogged.
Old 01-19-2013, 06:19 PM
djjab57's Avatar
Can you post the heater core part number, II was just on your site looking for it but didnt see it though im sure its there in that list somewhere
http://shbox.com/1/Parts.htm
Old 01-19-2013, 06:26 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I tried searching shoebox's site for "core", because I'm smart like that, and found this.
1993-2002 heater core
AC-Delco # 15-60051 52468039
Looks like the gm part number is 52468039
Is it difficult to replace the heater core in these cars? I just replaced the heater core in my 2001 Jeep Grand Cherokee and it was a bit of a job. The dash had to come out to get to the HVAC assembly, which also had to be removed, disassembled etc.
Old 01-19-2013, 06:30 PM
02v8ta's Avatar
Dash doesn't have to come out on the fbody luckily. If I can do it you all canl just the glove box assembly has to come apart.
Old 01-19-2013, 06:37 PM
djjab57's Avatar
Not hard to change just take out the glove box
Old 01-19-2013, 06:43 PM
djjab57's Avatar
Im just going to get the SPECTRA PREMIUM 94760 The AC Delco is just way to much
Old 01-19-2013, 07:08 PM
speed_demon24's Avatar
Google advancedautopart coupons. I found one for 30% off when I got my heater core. And my heat worked fine with my old and new heater core when it was 30 out.
Old 01-19-2013, 07:18 PM
Yes I flushed both ways through the hoses, I guess its my core then. At this point I don't care since the car is running well, I'll deal with it for the next 2 months or so. Next year I'll definitely replace it, good to hear the dash doesn't have to come out.. I know on some cars its a real nightmare.
Quick Reply: LT1, heater core flushed and still no heat.
