Solid or poly motor mounts?
Looking for feedback from anyone who has run both.
I have a set of both.
Will either increase the amount of knock the PCM detects?
Pros and cons of either?
Time for winter mods.:
Long-tube headers
LT4 knock module
Mcleod dual disk clutch
Line-lock
Long-tube headers
LT4 knock module
Line-lock
9-Second Club
Your results may vary. :-)
Long-tube headers
LT4 knock module
Line-lock
Long-tube headers
LT4 knock module
Line-lock
OP -
I removed my solid mounts and went with poly units to match my trans mount - much better; firm but not excessive.
Full disclosure: I have no experience with 'good' rubber / stock units, as my bird's stock mounts were sagging when I purchased the car (in 04 at 77k miles)
Poly all around is my vote, but good stock units might be OK too...
I just installed some Pacesetters long tubes and when under accelartion, it bangs against something. My car has the stock rubber mounts with only 30K on them but still a 16 year old car. Did the polys up front resolved this issue?
I did poly mounts when I did my LTs, my stock 160k rubber mounts were shot. You get a little more vibration but nothing to bad, I still DD my car.
My drivers side y pipe did hit the floor a little when I first installed them, massaged the Y pipe and problem solved.
For the $250? I paid for the LTs and Y its hard to argue the price of the pacesetters, best mod I did to my car so far.
