Trans mount problems/ driveline vibration
Old 01-24-2013, 09:58 PM
MRFecht's Avatar
Default Trans mount problems/ driveline vibration
Well after I put the longtube headers and off road y pipe on my car has had horrible vibration through the drive line. When I put the new clutch I replaced a broken trans mount on the bottom of the transmission. When you are cruising at 35 in 4th gear and get on it a little the trans jumps and it is also is really bad when going 65 in 6th gear. Should I consider getting my driveshaft re balanced and replacing the ujoints along with all the trans mounts? Just trying to figure out why it vibrates like it does.
Old 01-26-2013, 02:54 PM
englundjd's Avatar
have you checked all the trans mounts yet?
LT1 driveshafts are not balanced from the factory.
U-joints are a maintenance item. you'll just have to check to see if you can wiggle the drive shaft, if it wiggles around a little you should probably replace them.
edit: the driveshaft and u-joints wouldn't cause the trans to move around like it does.
Old 01-26-2013, 11:57 PM
cardo0's Avatar
Default Have a good shop inspect it.
Try your favorite trans shop and let them take a look while the car is in the air on the lift. My Z was missing a trans mount bolt and the other one was loose - not long after my new trans install.
Good luck,
cardo
Quick Reply: Trans mount problems/ driveline vibration
