Guess my numbers
Old 01-30-2013, 05:21 PM
nascarnate326's Avatar
Default Guess my numbers
Doing a fresh build of my motor.
350in LT1
LT4 hotcam kit
643 heads
Standard water pump
LT headers
Tune
6 speed
K&N intake
Impala gasket
Think it will hit 350 RWHP?
Old 01-30-2013, 06:16 PM
guppymech's Avatar
330hp maybe more if you use better valve springs than the kit springs.
Old 01-31-2013, 08:54 AM
bufmatmuslepants's Avatar
320-330 is what is typically seen. 350 absolutely not.
Old 01-31-2013, 09:29 AM
bowtienut's Avatar
heheheh........sounds like a CHALLENGE !
If he puts his mind to it and those heads are properly freshened, he could get it through an M6.
Guppy's right; it will take better springs.
Old 01-31-2013, 10:40 AM
cprmn14's Avatar
Get alittle bigger cam if you want 350. But I dont see you being too far off your goal.
Old 01-31-2013, 10:55 AM
Chopstix's Avatar
breathe on the hydrometer while it is being dyno'd
Old 01-31-2013, 01:51 PM
guppymech's Avatar
Those Impy head gaskets will give you alittle boost over the typical hotcam build. They're near the top of my 'to do' list.
Old 02-01-2013, 05:35 AM
I will classify my heads as "cleaned up".
All casting marks have been removed and intake/exhaust have been smoothed over a bit. They are still stock heads.
So it should like 330 would be a more realistic goal then?
Not a huge issue(it is a hot cam after all) but I was curious what a fresh build is worth over something with a bunch of miles on it.
Quick Reply: Guess my numbers
