Multi function switch?!
So the lever(turn signal switch) broke today when I tried to turn my highbeams off and now there stuck on. I tried and tried to pull the switch inward and nothing happens. Im sure some of you have had the same problem but there might be 2 parts im looking to replace.
#1. http://www.rockauto.com/catalog/more...739&cc=1035874
Or
#2. http://www.rockauto.com/catalog/more...018&cc=1035874
Should I replace both or only one of which?
One more thing. There is a oil Vaporizer hose that runs from the top of the passengers valve cover into the throttle body. It cracked and I need a part number or part name to get that fixed! Thanx
Or
I don't understand what you broke. Did you physically break the multifunction lever (#2) or do the high beams just not work anymore? The high beam switch is located on the steering column next to the starter switch, and is neither part you posted. This is the high beam (dimmer) switch:
http://www.rockauto.com/catalog/more...275&cc=1035964
As for the vacuum hose, it's the filtered air supply for the PCV system. Just replace it with some parts store vacuum hose.
Take it apart and look at it, when mine did what yours is doing it was just a little plastic linkage that had popped off, popped it back in place and it was fixed, no parts were required.
