My first top-end build
Over the years I have bought most of my bolt-on upgrades, including brand new wheels and tires, (see signature) on Craigslist for dirt cheap.
I started collecting pieces for my top end build on my 134K (not hard) miles LT1 Z28.
Goals:
• 300 + hp at the wheels
• Fix oil leaks in the front of the motor
• Pass CA smog – Very clean now with a brand new OEM single cat - original owner bought new in 2009 and never installed it.
• Keep daily driver / weekend cruiser quality
• Do it on the cheap (buy new where I need to)
Bought OEM AL heads, cam, and intake on CL for $180 and dropped them off at my machine shop for porting, valve job, matching ported intake, and custom ground cam. No hurry on shop work since originals are still on car. Will post flow numbers in a couple of weeks.
Upgrade plans for top end:
• Custom grind cam (224/224 .525/.525 lsa112)
• New Comp cam 1.6 NSA roller rockers
• New Spring set, seals, and hardened 7.2 pushrods from Alex Parts
• New GM guide plates
• New 7/16 posts
• 30lbs injectors ?? See below
Other new stuff:
• Harmonic balancer
• Water pump
• Timing chain set
• Front end oil seals
• Gaskets
• Tune
Questions:
• Do I need a 52mm TB or will stock be adequate?
• Can the OEM TB be bored out to 52mm
• Do I need the 30 lbs (or higher) injectors?
• Do I need a new opti? (Mine is a 2yr old GM part)
• Are stock head bolts OK?
• Do I need to buy new push rods? (I have read that the stock rods are hardened)
• What am I forgetting?
Thanks
Goals:
• New 7/16 posts
Other new stuff:
• Harmonic balancer
• Water pump
• Timing chain set
• Gaskets
• Tune
Questions:
Thanks
my comments below
Questions:
after H/C it can be of benefit. you need a tune to accomadate, especially for automatic cars
yes and better to bore a stock vs go aftermarket.
most would say yes, especially under WOT sustained (1/4 mi) conditions, FORD SVO 30's red tops. also requires PCM adjustment
if it works, no. certainly inspect cap/rotor and put blue lock tite on rotor screws. if cap & rotor are worn just replace with MSD cap/rotor kit
I would replace with 12pt ARP
with guide plates you do need hardened. Not sure what years LT1 had hardened. more important is a thicker wall PR as the stock ones can flex under high RPM which your new motor will see more of. Trick Flow is what I use .080 wall thick hardened. Given heads/cam I would use a PR check tool to see what length you need.
may now need a 255 gph Walbro fuel pump
Thanks
Thanks
Who's cutting you that 224/224, sounds like a tpi cam. These motors have shitty exhaust flow so normally you see bigger exhaust numbers, like 224/230.
93 and 94 had hardened pushrods, and THINK early 95. To check there will be a little dot on one end where they did the hardness test.
What are AL heads? (Nevermind, I'm guessing aluminum)
Back to that cam inquire, by those specs I'm guessing he hasn't done much with lt1s before, are you sure you want to let him play with your heads?
ported heads and roller rockers would be recipe for some new pushrods, get a pushrod length checker to figure out what size you need... all and all thought head and cam will net you above your hp goals if done right...
low lift "custom" single pattern cam?
Are you committed to do this wrong or do you still have time to back out entirely and wait till you have some idea of what is good before you try and do it wrong again?
If the shop suggested that cam I would think twice before letting them touch the heads.
I would diff look into another cam. Like already said most lt1 cams have higher exhaust numbers. I would also leave the stock tb and injectors. They will be more than enough for your combo. I would diff buy new arp head bolts. Youll will have to measure for the right pushrod lenght. Also if your not have blocked decked. Then i would run victor reinz .026 head gaskets. That will add some compression. Good luck
Mr Gasket also makes compressed .026 gaskets.
.026 gaskets and head/blow will net you around 11.4:1 compression.
A lovely bump up from the 10.4:1 stock compression.
This along with bolt ons will hit 300rwhp.
Adding a cam will just be additional hp.
My 95 is a federal vehicle, not CA, so that is how I get by with the single cat.
Yes it is an OBD1 car with the OBD2 plug - Loads of problems the last time I went through smog. Finding the OEM cat was a life saver.
No I am not locked into the cam so I can change.
