94 lt1 new cam
Sounds like one of the grinds LE and I talked about for my build. The lift was quite a bit higher than this one but the duration and LSA were the same. I ended up going bigger on the duration and lift in the end.
IT's going in my LT1 build for the spring...plan on going forge bottom end, LE trick flow heads, and 200-250 shot idk...but wants been done somewhat full bolt-on's; LE ported intake, 58mm TB, OBX longtube headres, cutout,3200 lockup stallfrom FTI, 4.10gears,nitto NT01 tires, mail in order tune by pcmforless.
