help about roller rockers? {newbie}
SO I plan on in stalling my cam a custom grind cam 231/239 571/.587110LSA and going with the 100.00 Alex parts valve springs[150.04] for everthing and was looking for some cheap 1.6RR...IM only being cheap because I saving for LE trickflow heads and a bigger cam...
I have 58mmTB, LT headers, 4.10gears, 3200 Stall...Just looking to by time to save more money...
Also why did you have a cam custom ground then you say you are saving up for a new one?
Yeah I could put a cam in my car right now, but I will be building a 385 this summer so why would I waste money on a cam that isn't going to be what I want for my 385?
So how many times do people change there setup...alot i had about 60% of parts bought bottom end, juice"go fast juice", headers,...stuff like that. What i didnt have was the rest of LE top end...intake(still waiting on) and heads thats why i never bought RR or VALVE springs...so i had a change of plans fill like going all motor no power adders...
So for the time being since Im down there why not put the cam in theres nothing else to do in St.Joseph MO...
dont run those springs with that cam. there not that durable. ask me how i know
Thanks for the info... Well i guess im going to get these than Lunati 73925K2 spring kit. Springs, retainers, locks, locators and seals. From LE for 250.00 is that good of go qith some thing else....and do i really need RRs...i dont care what these other people think i just dont want to be that dude at the track standing there...
Watch out for cheap rocker arms too. I have plenty of broken rockers from our 355 that had a .609 lift solid roller. We've broken Pro form's HD series, bent Harland sharps, and broke some Omega gear crap. I understand the budget thing, but I really like Comp's pro magnums. A much bigger fulcrum to spread the load, but our Dragster has Crane golds (came with the car), and they seem to hold up well too. The springs on the Dragster are 700#/inch, and sees just under 8 grand. A true testament to the Cranes durability. If you must go cheap, go to Ohio Crankshaft's site.
Also, be sure to check your clearance for the 1.6 RRs. You may have to remove material from the inside (closer to the rocker stud) of the pushrod hole. I'm not sure if LT1s have this issue, but many Gen I heads do.
Thanks for the site you think they will last about 4 months...
Can i use stock pushrods or will 7.200 pushrods work...and do i need guide plates if there 7.200 reason a friends has some that he will give me
You'll need to figure out the length. This is done by picking up an adjustable push rod and a "test" spring on the valve. You need to rotate the engine and look at the rocker's position on the valve. The OC rockers aren't self aligning so hardend pushrods, and guideplates would be recommended.
