to hotwire or not?
to hotwire or not?
I'm replacing my failing fuel pump with the walbro 255. Like everything else with lt1 there are many ideas behind parts and what need to and doesn't need to be done. Is the hotwire set up necessary or is it an option? Any input is appreciated.
I would do it. I'm changing out with a racetronix unit and the pre-made wire harness. Its cheap insurance IMHO, the stock wiring driving your new shiny pump is now around 19 years old, give or take.
Well that made the decision easy. Yea. I should have taken the age of the wires into account. I'm more of a mechanical person than an electrician. How much of a pain is the hotwire kit to install?
LS1TECH Sponsor
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
im using the racetronix pump without the hotwire kit, i was on a budget and in between a cross country move so i figured i would pass on the hotwire kit for the time being. i also agree that it would be good to replace old wires and better to draw power directly from the alternator. That being said i do not experience any problems without the hotwire kit, previous pump would sometimes cut out around 4500 5000 which has now been resolved with just the new pump.
@96z that's what mine is doing and of course everyone says its the opti. While anything electronic can fail I'm pretty sure its not the opti especially after I replaced the msd that was on it and it still acted the same. Its been tuned three times with same results a little stumble and loss of power. The logs showed lean at WOT and I was told that it was a result of bad o2 sensors or an exhaust leak. I started research and found many having the same issue after a build.
The best way to find out if a fuel pump is failing is to attach a fuel pressure guage and monitor the car at idle, regular driving, WOT, and after it has sat for a bit to see how quickly the pressure bleeds off.
