What to do with cooling fan on 12 rib Procharger
Old 04-09-2013, 09:08 PM
ringmaster72's Avatar
Default What to do with cooling fan on 12 rib Procharger
What is the best cure for the D/S fan with a 12 rib setup? Can I get a slimmer fan for the D/S, just run one fan or what?
Old 04-09-2013, 11:44 PM
MEAN LT1's Avatar
Trim it....alot. Your going to have to cut alot of the webbing from the fan to make it work but it will work.
Old 04-10-2013, 07:20 AM
I didn't get a chance to spend much time on it last night before I went in, but it looked to me like the fan motor itself hits the pulley as well.
Old 04-10-2013, 08:30 AM
lt1needingboost's Avatar
You are probably gonna need to stand your radiator up im guessing. I had to with a 8rib setup only because i used a thicker griffin radiator, a small amount of fabrication involved to get my 4" from my FMIC to my TB.
Old 04-10-2013, 08:34 AM
Or i have seen guys in the FI section talk abt going to a 18" single pusher fan, u could try a pusher/puller on the opposite side of your SC.
Old 04-10-2013, 03:16 PM
ramair96ws6's Avatar
The kit should hvae come with spacers to space the fan. I have the stock setup on my car with a cog drive set up and there is plenty of room.
Old 04-12-2013, 10:26 AM
SRZ
SRZ's Avatar
12 rib here w/ the stock fans and Fluidyne rad and have no clearance issues.
Old 04-12-2013, 06:34 PM
I got it taken care of. I made a piece of angled steel that fit between the radiator bracket and the fan bracket that pulled it 1/4-1/2 inch closer to the radiator. This got me the clearance I needed.
Old 04-12-2013, 08:28 PM
Blackbirdws6's Avatar
As mentioned, kit should come with spacers to bring the fan motor away from the pulley. The shroud will need considerable trimming. Stock fans and rad here with no problems.
Old 04-12-2013, 09:37 PM
I pieced together a kit, so I didnt have any spacers.
Old 04-13-2013, 05:57 AM
Perhaps call Procharger and get them?
Quick Reply: What to do with cooling fan on 12 rib Procharger
