N20 and cam questions.
hey guys another n20 and cam build question thread. Here is what i have been thinking about, and what i hope to learn.
From my understanding the lt1 can handle n20 pretty well if tuned properly and if its in good running shape right?
What is a safe shot if tuned, and on a fresh motor. I have an extra lt1 that has around 80xxx miles that i can have sent off to be redone or freshened up.
here is what my plans are if i go this route, and please steer me in the rite path if im wrong.
1.ARP rod bolt's
2.stock rods and crank, gone over.
3.cc306 or a custom grind with all supporting mods, lifters, pushrods, 1.6rr's,spring ect
4.Forged pistons, i dont know which would be good for this. Maybe howards cams forged??? Any suggestions
5.msd opti, and 6al. From research both are a good choice.
Things im curious about
1. How do the stock rods, and crank handle n20? If i dont have to i wont bore it, but i will put new pistons in it.
2.Can i rev past 6200 with rods bolt's forged pistons?
3. which n20 kit? zex, nx outlet, nos??
What can i expect from a cammed, stalled, geared and suspension n20 build.
One reason i want to do this is i can always build upon the n20, and add more as the car grows, for now im just planning. Will be on stock heads for now till i can figure out which one to go with. Thanks again everyone!!
1.ARP rod bolt's
Get arp bolts with a custom nos cam then tune it. Spray a 150-200 shot and let her rip
No more than a 200 shot to stay in the safe zone...
What year is your motor? 92-94 (or 95 I can't remember) had the better rods, and those rods are not known for any failures. The stock crank is not going to give any trouble. With a forged lightweight piston and a well tuned setup you can spray the **** out of it with that setup as far as the stock PCM can handle, or about 7000 rpm. Pick up a used 306 for $100 and build from there. Use some 0.026 gaskets to bump your compression and let her rip. once funds come you will have a strong short lock to build on. There are guys running stock pistons rods and crank with arp bolts to 7000 rpm with no issues.
