Power Steering AN lines...
Old 04-10-2013, 10:23 PM
SoxXpupPeT's Avatar
Default Power Steering AN lines...
I will be replacing my worn, tired old power steering rack aswell as rebuilding my power steering pump soon. I will also be adding in a oil cooler, and changing the line out to stainless steel lines with AN fittings. I need to confirm the fitting that will fit into the power steering pump. I did a search and came up with This link. Its for an ls1, is the fitting going to be the same, or no? I want to get everything ordered before i dig into it. Thanks
Old 04-11-2013, 07:01 AM
Man-Crush Warning
Shownomercy's Avatar
AER-FBM2608 -6 AN to 16mm x 1.5 Male
AER-FBM2609 -6 AN to 18mm x 1.5 Male
Old 04-11-2013, 05:23 PM
SoxXpupPeT's Avatar
Thanks I already have the part numbers. I was just wanting ot make sure if the same fitting will fit into the LT1 power steering pump as it will the LS1.
Also. On which side should i run the cooler. On the pressure side to the rack or on the return side from the rack? Thanks
Old 04-11-2013, 05:29 PM
gjohnsonws6's Avatar
Be sure to use the ptfe hose and fittings. Regular ss braid and aluminum fittings are not rated for use on the high side.
Return side
Old 04-11-2013, 09:59 PM
SoxXpupPeT's Avatar
Thanks for the reply John. I make hydraulic hoses in my machine shop so for the high side ill use a hose rated for 2k psi. That should be sufficient. I hope lol
Quick Reply: Power Steering AN lines...
