Opinion for exhaust for the car
I must be getting old but it is just too loud. Headers, xpipe with bullets and turn downs is a little much. Great for power but horrible for the neighbors and cops
I was looking at the true dual kooks setup but damn its crazy in cost! I wish I could hear it in person. I am thinking about just a nice cat back with dual e-cutouts.
What would you guys recommend? The car should be around 850-900 rwhp
Thanks
Steve
Thanks
Steve
The specs on the motor and car are as follows
LT4 Competion heads Flow numbers are 324 241 @.600 2.10 1.6 valves
Jessel Pro Series Shaft mount rockers 1.6/1.55
Bullet racing cam 242/248 112 lsa 626/608
Edelbrock LT4 intake completely ported by Lloyd Elliot (no flow numbers)
Arizona Speed and Marine Mono Blade throttle body
Splayed 4 bolt main block
Callies Dragon Slayer Crank
Dyer 300M Rods
Custom JE pistons with Hellfire rings
F1A pullied for 73500ish@ 6500 rpms (Max is 74000) Whatever boost it makes, it makes
Spearco Air to water intercooler with a 5 gallon remote reservoir
Custom built LTCC with relocated coil packs and custom Moroso Wires
FAST Classic Piggy backed to the stock PCM so Passing Smog is easy
Kooks 1 3/4 to 1 7/8 stepped headers with a 3 inch collectors
Custom 3'" x pipe and true duals to dynomax bullets and turn downs
Full Madman Chromalloy Suspension with AFCO shocks
Rossler 4L80E trans with a brake and full manual valve body
Moser 12 bolt 3:73 Gears.
10 point wolfe cage with window net
10# halon fire suppression kit
Aeromotive eliminator pump with a #10 feed and #8 return 95# fast injectors
Dyer 300M Rods
I agree with you steve seeing your car in person inspired me to go true duals ,however it is just a lil too loud. Im going with GMMG. By the way I saw you driving the TA down Nellis a couple weeks back on my way to work didnt sound bad at all Lmao...
To be honest I am to. I have had it since 1998 and the paint and interior still look almost brand new. It just turned 43K miles th other day on the way to work.
Maybe on the next build.
Don't get me wrong, it sounds mean as Fvuck, it is just a little much haha. I try to drive it on Fridays to work as I go in early and can get the prime parking. I want to drive it as much as I can before the hot temps get here as it no longer has A/C!!
Thanks
Steve
Thanks
Steve
You would be surprised what just running the exhaust out the back of the car will do to interior noise. I ran a similar setup (kooks, x pipe, spiral flows dumped at the axle) and it was just crazy. Sounded great at stop lights and all but I couldn't hear the stereo unless it was at hearing loss levels. At the moment I am running Kooks stepped headers, 3" y pipe to a 4" catback with spintech muffler. I also have cutouts for annoying the neighbors at 3 AM (jerks like to rev their harleys when I'm trying to sleep during the day). I also put dynamat (sp?) all through the car which helped a ton.
I love how it sounds at stop lights the looks are great too lol
well to just quiet it down the borla catback is not a bad option at all, especially with the different plates you can toss in. But at like 900 new ish it's on the high side of things lol. I'm going on the hunt for either that or a gmmg for mine, me thinks slp LM2 plus ORY and LT'S is going to get annoying quick.
I would assume with that much power you would benifet from a 4" system?
About a year ago I helped a buddy with a 4" catback. He didn't like the mufflers that came with any of the 4" catback systems on the market. We ended up using a hooker aerochamber muffler and a mufflex cat back system and combined them.
We used dual 3" pipes for the Y-pipe which merged with a flowmaster merge (dual 3" into a single 4") to mate with the catback. The hooker comes with a 3" inlet but the inlet is cone shaped down to the 3" OD. If you cut the inlet off right at the muffler it is a 4" opening to accept the larger 4" cat back. It took a fair amount of cutting and welding but it turned out very nice and really couldn't tell it was all pieced together when we were finished.
My buddy and myself had both been running the aerochamber cat back 3" system and liked the sound of it which is why we went with that muffler on the 4" setup. We were both really surprised at how much the sound chaged by just going from the 3" to the 4" catback with the same muffer. Sounds much deeper but seemed to quiet it down a little.
