a rock fell in my injector hole
How can I get this out? I thought I cleaned off the area enough before I pulled the fuel rail but there was a small rock hiding between the injector and the intake. When I pulled the fuel rail off it fell into the #8 cylinder hole
Remove the spark plug, tape a small hose on an wet and dry vacumme and try to suck it back out the injector hole. Clean the vac first so you could inspect it.
