Calling "Stood Up" Radiator People (Hoses)
I was working on mounting the radiator last night and started looking into radiator hoses. I figured I would ask on here before I start hacking up hoses.
What hoses did you guys use? Part #s would be a plus
Thanks
Thanks
HAHA I know, but I have a pin on hood now and I don't plan on showing the engine bay off anymore
Jeez man you have a lot going on in there Where the hell is the radiator though? Do you have it mounted flat in the nose?
I think I will weld on some AN fittings and go that route before piecing sections of pipes together, but that will add a lot to the cost and I'm running out of money to stick into this thing I just don't want a clamp coming loose and end up spraying coolant everywhere, I had that happen last year with one of the clamps for the heater hose. Sprayed coolant all over everything and I lost the alternator and power steering from the slipping belt, was not a fun ride home
^^^^Thanks a lot I thought about getting those but wasn't sure it they would fit on the water pump or the radiator since they are 4 different sizes now. Did you have to get anything special or is it just a universal kit with a bunch of different sized ends?
Thanks, I looked a little last night and the kits I found were around $65 for a 48" hose with adapters. I'm going to try to make a stock style hose fit that way if something goes wrong I can always grab it at a parts store rather than having to order it online. I will definitely keep these in mind though
