AC Compressor Going Bad?
Old 05-08-2013, 11:12 PM
96LT1Z's Avatar
Default AC Compressor Going Bad?
Recently been noticing a drag down or bog on the motor whenever I use the AC in my car. I have had one suggestion that the compressor might be going out. I am very interested because I have never heard of this happening. Obviously it could. Just let me know what you think
Old 05-09-2013, 07:47 AM
Village Troll
SS RRR's Avatar
Are you saying it's dragging the motor down more than normal? There is a very noticeable difference with and without the compressor on. Usually if they go bad they either leak or make noise.
Old 05-09-2013, 07:59 AM
96LT1Z's Avatar
Exactly what you just said is happening. I have a thread about it, check it out
Old 05-09-2013, 08:52 AM
Village Troll
SS RRR's Avatar
Take the belt off, try to turn the very front of the compressor. It should have resistance, but should be able to be turned by hand. If it's extremely hard to turn then it may be going out, but again, usually compressors show signs of going out other than dragging. Now turn the part the belt seats on. It should turn extremely free. I also think the belt would start slipping, also making noise, if the compressor had more resistance.
As stated in your other thread, have you checked anything suggested? If not, check your plug wires. Check to see if the water pump is leaking onto the opti (check when engine is warm and system is pressurized). When is the last time plugs/wires were changed out, if ever?
Old 05-09-2013, 11:50 AM
96LT1Z's Avatar
I changed plugs just a couple months ago. I did not do wires however..
Quick Reply: AC Compressor Going Bad?
