Went from 93' wiring, to 95', now I can't get any fuel!
LS1Tech Sponsor
The small one way connector that looks like its in your hand is just for testing or priming the pump.
What wiring did you change? the dash harness or the interior harness?
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
The prime lead is only for testing. You don't normally connect it to anything. What did you use for a guide for matching up leads between the two years? Some adaptation is required. You can find lead differences here.
edit: just realized you ARE shbox! I'm not worthy!
I read somewhere that if the computer doesn't read any oil pressure or anything that it won't allow the fuel pump to work. Can anyone confirm this?
upon further inspection, it looks like I broke both of my oil pressure sensors putting the motor in( though I think one was already broken)
****. Well anyway, I got a wire and touched the prime lead to the battery and it primed the pump, so I know it isn't the pump itself. I guess I will just have to get a voltage and pressure tester and do some troubleshooting
LS1Tech Sponsor
You changed the dash harness to the 95, engine harness to 95, and the engine to 95. All this is correct?
__________________
1-888-467-4491
1-888-467-4491
Just checked my relay wires with a voltmeter, and the red wire has 12 volts, but the other three don't. Is the red one the only wire that should show voltage?
-Pink should have +12v with key on.
-Dark green/white should have +12v when the computer commands the pump on (for 2 seconds when the key is first turned on and continuously after the engine is running)
-Black/White = continuous ground
-Gray = +12v to pump when relay is activated
What red wire? http://shbox.com/1/1995_pcm3.jpg
pink: 12v
green/white: a very small reading at first then nothing
gray: nothing
at the connector behind the back seat:
the first hole(larger one): nothing
the middle: 7.5v
the last: nothing
the relay never clicks on(I have three of them and none worked)
the vats module I am using is from mu 93' (it is the only one that allows the car to turn over, and the security light goes of after 2 seconds)
. the 95' module will flash security and won't let me do anything.
my circuit tester only lights up on the pink wire at the relay, and at the middle wire at the connector(though it glows faintly for that wire)
first of all, sorry for the long windedness, but I know that more info makes it easier.
second of all, you are a saint, thanks for all the help so far!
You may need to ohm out the green/white wire to make sure it is good from the relay to the PCM. It should be checked to be sure it is not grounded, also.
When measuring the green and white wire right after the computer, it will show a very small voltage reading right after turning on the key, but it is negligible (usually less than 1v) and it immediately goes away. I am getting power from the ignition and battery wires to the pcm though, so something is not letting the pcm send power to the relay.
could it be because I am using a 95' ecu and wiring harnesses with a 93' vats module?
