When will it stop, motor locked up
So if the bad news with the clutch could not be bad enough, I went to start the car to make sure my rear main seal was not dripping. I had drove the car a few days ago after the rear main seal swap and found the clutch problems. Car drove decent then after a pull were I found the clutch problem it felt like a big vacuum leak behind the mass air flow. So parked the car since it was late. Went out today and checked the maf to find it was a little loose and maybe having a leak. So fixed that and went to start the car. Starter made some bad noises. So looked under to find a broken starter. So got a new starter installed it. Turn the key same thing. Broken Starter. So instead of checking before I put the new one in I go to turn the engine. Grab the 18 inch breaker bar and cant turn the motor forwards or backwards.
Car had normal oil pressure and the temps were good when I had turned the car off on the last drive. I am stumped. What should I do. I am just ready pour gas over the whole dam thing and light it on fire. I swear this car is cursed. 4.5 years of trouble.
Alright bringing this thread back up. Finally had time to pull the plugs and check stuff. First off I did get the engine to move with a breaker bar. Feels very tight and hard to turn. Moved it back then got a full turnout of it. The whole time it did not feel happy. Pulled the inspection plate and the flywheel and the clutch look normal. So that should not the the problem for then locked up motor. Thought I would check since I just did the rear main seal which is now leaking AGAIN.
So pulled the plugs. #7 had some gas on it but the wire was a little loose. Number #8 was rusty like it had been in water. The other plugs either look normal or like they had water on them. Here are some shots. Order from left to right. 1,3,5,7 and second row 2,4,6,8.
Bank 1
Bank 2
So while pulling number two I had to remove the oil cap. Easy way to get the plugs out. Found this.....
This was not there before the 5 mile drive after the rear main seal drive. Everything was dry when the fresh Castrol oil went in. So I am thinking maybe the car blew a head gasket while on the drive and maybe hydrolocked.
Oil looks like water on the dipstick as well.
Any Ideas. I am just ready to sell the whole car cheap. Its been 4.5 years of bad luck. I know I am not pulling the motor again.
Bank 1
Bank 2
Hard to read the plugs for signs of super lean conditions being as though it was not driven for long in that manner. Any chance you can do a leak down/pressure test to isolate which cylinders were the culprits?
Sucks the motor hydrolocked due to the bad headgasket.
Yeah it was running great up to this point. Was surprised to find this. Wideband in the car was reading 15-17 idle,12-15 driving,11.-12.6 at wot. Its the AEM wideband. Was going to rich the idle up some other than that it was great.
i don't know my oil looked like that on cold winter days when id start the car but not drive it anywhere... something about condenstation and not running long enough. But since its mid summer there is a good chancce it could be a head gasket. Sucks your having all these troubles...
I feel for ya, man.
I had the EXACT same thing happen to one of my Impalas last year. I broke 3 starters in a 4 week period. Oil cap looked fine, but when I pulled the plugs, I had coolent flowing out from cylinder #2.
From my perspective......it's time to sell the car or an opportunity (excuse) to build the engine of your dreams.
Best of luck!!
KW
Best of luck!!
KW
Pull the valve covers, if the head gasket went the milky mess will be everywhere.
When my motor locked up due to fuel I knew right away, fuel poured out of the cylinders as I pulled the plugs, it was due to a faulty regulator, if you take the vacuum line off and turn the car on, if it is bad fuel will shoot out of the regulator.
I feel for ya, man.
Best of luck!!
KW
Best of luck!!
KW
Ouch....I had a similar issue with my new 383 with a bad/not installed properly RMS, it leaked all over my new RAM HD clutch and killed it in short order Just curious, did the car sit a long time without running before it blew a head gasket? My old stock engine blew a head gasket within a week of getting it back on the road after it was out of commision 2-3 years. I would not blame you to sell it or LS swap it. How many miles are on it?
Village Troll
Built the motor around January. Got the engine in the car about March time. Broke it in and had the teflon rear main puke its guts. Drove it 300 miles before the leak got bad. Car sat about a month. Then drove onto a trailer while I moved back home. After than it sat 3 weeks to change the seal out. Then two days for the drive after the new rear main seal. Only 300 or so miles on the motor. Car has 158k.
Also budget is gone. This last rebuild was done on my parents dime kinda for a graduation gift. I have no budget to fix it or even the will to fix it. I'm done.
Village Troll
Teflon doesn't give out that easily unless it's installed wrong or something else is amiss. If this isn't top end related you need to take the block to another shop and have them check out the block to see if it's true. If it did hydrolock then most likely you have a rod or two that is no longer straight.
