Go Back   LS1TECH > SBC-BBC-LT1-LT4 PERFORMANCE > LT1-LT4 Modifications
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Used CarsVendor Directory
Search
1993-97 Gen II Small Block V8
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 06-12-2013, 11:47 PM   #1
Garage is empty, add now
94 z28 A4's Avatar
Trader Rating: 0
Default 93 z28 shutoff while cruising. No warning. Won't start now
My dad was driving his 93 z28.. Was in 2nd gear fixing to shift to 3rd and all of a sudden it just shut off. He let it coast to a stop but before he pulled it off the highway (car is shut off) it backfired. Not real loud. Tried to restart it but all it would do was roll over. Just like its not getting fire. He bought a new coil and wire but still no fire. Help would be greatly appreciated. The opti was replaced like 25k miles ago so I don't think it would be that. He did see that the plug wire on the coil was arching that's why he replaced that wire and the coil. He said the fuel pump still primes when he turns the key. Could it be a clogged fuel filter, maybe a ground wire came loose somewhere? If it was a ground wire then it prob wouldn't even try to turn over right? Could it be a sensor? Please help ASAP! Thanks in advance!
__________________
White 95 z28, stock motor, built tranny, 3000 stall, magnaflow, chrome zr1 wheels
94 z28 A4 is offline   Reply With Quote
Old 06-13-2013, 06:20 AM   #2
cprmn14's Avatar
Trader Rating: 0
What brand is the opti? Wouldnt be suprised if it took a dump. I had a new GM model with 0 miles and it was a dud. Never know. Id check fuses aswell.
__________________
91 RS, Full Exhaust
Work In Progress:http://ls1tech.com/forums/lt1-lt4-mo...-my-91-rs.html
cprmn14 is offline   Reply With Quote
Old 06-13-2013, 06:38 AM   #3
joelster's Avatar
Trader Rating: 0
Sounds like the rotor broke apart. If you have power coming OUT of the coil, but none at the plug.....
One of the most important things you HAVE to do when replacing an opti-spark, is to remove the rotor bolts and then loctite them in place.
__________________
'94 Z28
414 cube LT1, AFR 227's, single plane
10.15 at 133.65, n/a pump gas, street car
'14 1LE, no track times yet
joelster is offline   Reply With Quote
Old 06-13-2013, 09:39 AM   #4
1994 Pontiac Firebird
My Garage
ahritchie's Avatar
Trader Rating: 1
I say your ICM possibly took a dump as they like to do...or the opti which is the number one suspect for those sort of symtoms as mentioned.
__________________
1994 Firebird Formula "The Purple car" Plum Crazy, 6spd, 383 with lots of engine and suspension mods..
1999 Firehawk Formula #37 Main DD, black, 6spd, longtubes, dyno tune, stock other than SLP options: level II suspension, hurst shifter, aurburn posi, SLP exhaust. More to come...
1966 Austin-Healey 3000 Mk III Toyota 5spd conversion, Proper English pimpmobile
1999 Buick Regal GS Supercharged! Project Old man sleeper/beater... 3.5" SLP pulley, K&N, 265hp/300+tq Stang/ricer slayer
ahritchie is offline   Reply With Quote
Old 06-13-2013, 03:17 PM   #5
94 z28 A4's Avatar
Trader Rating: 0
Thanks guys for the replies... He is gonna try to pull the codes later. It's getting fuel to the motor but he is gonna hook a fuel pressure gauge to it just to see how much pressure it's putting out. Just praying it isn't the opti. If it is the opti what is about the average price a mechanic charges to install it?
__________________
Old 06-13-2013, 03:42 PM   #6
shbox's Avatar
Trader Rating: 0
I'd bet on the opti. Don't know about shop charges. Mine never goes to one. Parts and labor I would expect $800+.
shbox is offline   Reply With Quote
Old 06-13-2013, 03:53 PM   #7
leadfoot4's Avatar
Trader Rating: 0
Quote:
If you still have the OE front pulley on the engine, why take it to a shop? The pulley is a 2 piece affair, designed to allow the Opti to come off without much hassle. The bolt pattern of the hub is asymmetrical, so when you unbolt the outer ring, and rotate it into the correct orientation, the "ears" of the hub provide just enough clearance for the Opti to slip off. NO WAY I'd bother with a shop....
leadfoot4 is offline   Reply With Quote
Old 06-13-2013, 04:01 PM   #8
My Garage
ahritchie's Avatar
Trader Rating: 1
It will cost you an arm and a leg and maybe your first born child if you go to a dealership I know that much....especially if they charge full price for a GM opti ($450 or something crazy), I believe it's something like a 7-8 hr "book" job (really takes them 3-4 hours if that) anywhere from $900-$1200....**** is ridiculous. A private shop would probably cost about half of that.
Better yet, do it yourself or ask a mechanically inclided friend to help out and supply the beer It's not quite as bad a job as everyone makes it out to be and you'll learn a lot! Two amatuers could easliy do it in an afternoon, just take your time.
__________________
Old 06-13-2013, 10:50 PM   #9
Trader Rating: 0
Happened to me one time on the freeway. It turned out to be a bad coil...msd and it was brand new. If not coil probably opti???
jeepbeast is offline   Reply With Quote
Old 06-14-2013, 06:48 AM   #10
94 z28 A4's Avatar
Trader Rating: 0
He has a friend coming over to look at it.. The guy use to work on lt1's a long time ago and replaced several opti's. He's a good friend so he prob won't hardly charge a thing to put the new one in. He is retired and has nothing else to do. Anyways... Do y'all happen to know what the fuel pressure is supposed to read when you check it with a manual gauge at the fuel rail?
__________________
Old 06-14-2013, 09:15 AM   #11
shbox's Avatar
Trader Rating: 0
41-47 psi when you prime it and same with engine running and vacuum line to the regulator removed. Everything connected, idle pressure will be much lower.
Old 06-27-2013, 08:22 PM   #12
94 z28 A4's Avatar
Trader Rating: 0
Default Update!
Got the car fixed... It was the cap and rotor. It came apart on the inside.. Put a new one on and runs great now. Thanks everyone for your replies. Thank you joelster
__________________
Old 06-28-2013, 06:36 AM   #13
joelster's Avatar
Trader Rating: 0
No problem! At least those parts are cheap, just a lot of labor to replace them.
__________________
'94 Z28
Old 06-29-2013, 10:17 PM   #14
94 z28 A4's Avatar
Trader Rating: 0
Yeah they were pretty cheap and he actually didn't charge much for labor. I was surprised.
__________________
Old 06-30-2013, 04:14 PM   #15
1993 Chevrolet Camaro
My Garage
Trader Rating: 1
First time I changed one it took 8 hours of me taking my time.
The last one I changed took 90 minutes. Practice makes perfect.
Good time to put in a new WP also.
pkincy is offline   Reply With Quote
Old 06-30-2013, 06:09 PM   #16
94 z28 A4's Avatar
Trader Rating: 0
Yeah we went ahead and put a new water pump on also along with a new t-stat
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
93, 94, 95, backfired, bad, bypass, camaro, cap, coil, crank, price, rotor, sensor, start, wont, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Statement - JOBS
Emails & Contact Details
