Who sells water pump drive seal tool?
Just looking for a water pump drive seal tool. Found someone selling but they are all out. Anyone know someone who has em for sale still around the $10?
You do know that you must slip that seal over the water pump drive shaft AFTER the timing cover is already installed on the engine ..... right???
I think(?) all the previous responders assumed you knew this, but ...... I'm not so sure you do??? All the "socket" and "sharpie" tricks they mentioned are used to slip the seal over the drive shaft after the timing cover is ON the engine. Got it???
ok i must not have looked at the seal correctly. you saying it needs to be installed with timing chain cover already on the engine? if so that explains why it f'd up. i just installed all 3 and then put the cover on.
You CAN install all 3 seals into the timing cover first, you just need something smooth, like a Sharpie cap, to slide the WP drive seal over the splines of the driveshaft, as you install the timing cover. A member of this forum, whose username escapes me at this moment, used to make and sell a tapered, metal sleeve for this job...
gotcha. ok so i did it wrong. learn something new i guess. ill pull that one and install a new one. im gonna assume thats exactly what i have leaking. ill pull the waterpump and check to be sure
If you did seals in TC then put TC on without some form of "tool" than it is a 99.9% chance the seal will fold over.
using a "tool" be it the same Kent Moore plastic thing, aftermarket one or a socket or sharpie pen cap is what you need to do.
I bought the Kent Moore damper hub remover/installer on ebay and it had the little plastic one in it. don't know if it comes with it but it was in the kit.
I am sure it is exploding wallet to buy but the Km tool # is J-39087
(holly batshiat it is $55! for a piece of plastic)
http://www.toolsource.com/drive-gear...-p-112357.html
Make sure you look at the seal. It has two seals in it. One is directed forward and one is directed back. Felpro seal has a yellow front seal that will point or lean out towards the water pump and the other looks like the opti seal and is directed (or pointed) towards the inside of the engine. If you can see the grey color seal sticking out just under the front seal out towards the water pump it is installed wrong.
ya im leaking oil pretty steadily im betting thats it. im going out there today to replace it. ill get the job done with a socket. i just didnt look at the seal or realize i needed to get it slipped over the gear correctly. just assumed is slid over and sealed.
thanks for the help guys
