MSD Super Conductors
Old 06-22-2013, 06:26 PM
xXMattXx36's Avatar
Default MSD Super Conductors
Has anybody used these and is familiar with them? I was going to do this when the spark plugs were done, but wires weren't in and I needed a vehicle.. It was a hard enough job doing the plugs and the wires looks like a pain too. The guy before me has the wires running up, through the headers(><) then in front of the waterpump and down to the opti.. Any suggestions? I want to run them below straight to the opti so I don't have much high heat worries(multiple of the old wires are burned).. Should I just cut to fit and zip tie them somewhere on the bottom end? Whoever can chime in, thanks
Old 06-22-2013, 06:33 PM
ramair 1's Avatar
i used them with the over the valve cover kit made by cc performance its a cool look and no more burnt wires .check there site out
Old 06-22-2013, 06:35 PM
rocket22's Avatar
I had them on mine and when i changed them went with the jegs house brand 8mm wires, the msd's arent worth the money. i left them under and shortened the back plug wires on each side
Old 06-22-2013, 06:48 PM
xXMattXx36's Avatar
http://imageshack.us/a/img17/9361/qzjt.jpg
http://imageshack.us/a/img13/3322/x2wm.jpg
Yeah my headers are funky and you cant really do a clean over valve cover setup. I already have the 8.5 msds lol so I might as well not waste money. Did you secure the wires anywhere, if so where?
Old 06-23-2013, 06:39 PM
pillarpod's Avatar
^^each is their own, but why would you run them like that?
Old 06-23-2013, 06:54 PM
Camaro350Z28's Avatar
passenger side is really the toughest. but there is a nice hole right next to the power steering pump that i routed that whole side through. it turned out great and they stay way clear of the headers. I do not like the OTVC look. I used to but after seeing it more and more.. i just think it bothers up the engine bay.
Just gotta take your time and there are plenty of ways to go by zip ties and keeping plenty distance from heat
Old 06-23-2013, 07:07 PM
Jason94z's Avatar
I used to have over the valve cover custom length make your own msd super conductors.
I changed to the pre made MSD superconductor lt1 kit and routed them like camaro350z28 did underneath, and it works much better.
Old 06-24-2013, 06:06 PM
xXMattXx36's Avatar
Well I got 6 of them changed. I have the 8.5 cut to fit as well... 3 different wires were damaged so severely, all you had to do was wiggle barely and it would tear apart.. I went with a under custom route, but couldn't get plugs 2 and 6 no matter what way I went, will have to drop headers. Does anybody else have a tough time putting the boot back on the opti with plug #8? I couldn't get it on all the way and was trying to for a couple hours, maybe its just my hand size.
And I didn't do those plugs and route, previous owner did... for unknown reasons lol.
New setup http://img837.imageshack.us/img837/8950/hx0b.jpg
http://img189.imageshack.us/img189/5249/qn8a.jpg
Old 06-26-2013, 07:51 AM
quik95lt1's Avatar
they work just need to be careful where you route them, with headers its WAY easier than on a stock car
Old 06-26-2013, 09:27 PM
xXMattXx36's Avatar
my headers make it complicated... -_-
Old 06-26-2013, 09:39 PM
pillarpod's Avatar
i doubt that, what brand are they? shorties, mids, LT?
Old 06-28-2013, 02:49 AM
xXMattXx36's Avatar
AS&M just look at the pics I posted in the links
Quick Reply: MSD Super Conductors
