Pic request: Fog light mounting on Trans-Am
Old 06-22-2013, 11:28 PM
Birdie2000's Avatar
Default Pic request: Fog light mounting on Trans-Am
Does anyone have a pic that shows how the fog lights mount on an LT1 T/A? When I purchased my TA the fog lights were removed and the bumper support was not the correct one for my car. I believe the fog lights mount to the bumper support somewhere?
Old 06-23-2013, 12:48 AM
Alex94TAGT's Avatar
Best I've got:
Pic request: Fog light mounting on Trans-Am-vgw9zik.jpg
I drew some arrows pointing to the foglight mounting bolts, two per side, four total:
Pic request: Fog light mounting on Trans-Am-xwcamte.jpg
Old 06-23-2013, 08:44 AM
Birdie2000's Avatar
Thanks! Do you remember... are those holes on the support beam threaded, or is there a nut you put on the other side?
Old 06-23-2013, 11:42 AM
Alex94TAGT's Avatar
The holes have a permanent threaded insert -- looks like a "rivet nut." Foglight brackets then attach with bolts, though I do not recall the size/thread.
If no modifications to your car require what you have now, it looks like Classic Industries sells a factory reproduction front bumper impact bar for $39.99, part number 1668026. Otherwise, could always try to find a replacement from a junkyard or part-out.
If it were me, and I didn't have a rivet nut tool, I'd probably just drill some holes and weld a nut to the back side (put a bolt in it to hold the nut in place while you tack it in place). Getting the alignment right would be the difficult part. You could probably get by with a bolt, washer and nylock nut -- though it would probably be a pain to reach with the front bumper installed.
Old 06-24-2013, 12:07 AM
Birdie2000's Avatar
Thanks, I appreciate it!
Quick Reply: Pic request: Fog light mounting on Trans-Am
