new cam time...
new cam time...
Alright so i finally just said screw it cause I couldnt figure out what was causing my problem and I just want a bigger cam. I'm going to get a new AI cam. I emailed them and they recommended the 228/234 and I think I will stick to that.
I'm going to order the cam with the Ai Complete HR Cam Kit:
Ai Billet Steel LTx Camshaft
Performance Springs Inc. MaxLife Beehive Springs
CompCams Beehive Spring Steel Retainers
Machined & Hardened Steel Locks / Keepers
CompCams Hardened Steel Spring Locators
OEM Quality Steel Jacketed Viton Seals
K-Line Valve Seal Installation Driver
ARP 7/16" Pro Series Rocker Studs
CompCams 7702 Pushrod Length Checking Tool
CompCams 1605 Ultra Pro-Mag Rocker Arms - 1.6 Ratio
Ai Hardened & Black Oxided Steel Guide Plates
Ai 4130 One Piece Chrome Moly Hardened Pushrods 5/16" x 7.XX" .080" Wall
Fel-Pro Gasket Kit - Timing Cover gasket, Water Pump gaskets, and Crank/Opti/Pump drive seals
Fel-Pro 1284 Intake Manifold Gaskets w/RTV
Now I know this is a pretty comprehensive kit so with that said, will I need anything else?
Will my LS7 lifters handle the 228/234 without any issues? They have about 22k miles on them
I'm planning to pull the heads and have them checked out, resurfaced, and get a thinner head gasket to bump the compression. Should I just get the 96' Impala SS gasket?
What should I do about head bolts? can I reuse the ones I have (new OEM LT1 bolts were used on the rebuild) or should I get new arp bolts?
I'm also looking for a good OTVC wire set, any recommendations?
Part numbers for these parts would be appreciated. Thank you
....... have them checked out, resurfaced, and get a thinner head gasket to bump the compression. Should I just get the 96' Impala SS gasket?
What should I do about head bolts? can I reuse the ones I have (new OEM LT1 bolts were used on the rebuild) or should I get new arp bolts......
ARP head bolts? You betcha !
Don't forget to have your PCM recalibrated.....
KW
thanks for the good reading!
