engine wire harness HELP...
Old 06-26-2013, 09:51 PM
stuntinZ28's Avatar
Default engine wire harness HELP...
Ok so I have a 94 trans am lt1 4l60e with a tore up engine harness. So I got a replacement out of a 95 Z28 Camaro lt1 4l60e. On the trans am I have 25 wires going thru the firewall into the car. But the Camaro harness has 22 does anyone have any idea what the other 3 wires could be. They go from computer to inside car. Any help is appreciated
Old 06-26-2013, 09:57 PM
merim123's Avatar
95 was obd1, 95 was obd1 with a obd2 connector. take pics and post up the ones you have questions on. also, c200,c210,c220 all change 'slightly' year over year, use shbox site to do a lookup year over year.
Old 06-26-2013, 10:12 PM
stuntinZ28's Avatar
Both ob-1 it looks the same 94-95
Old 06-26-2013, 10:14 PM
stuntinZ28's Avatar
What do c200,c210,c220 go to I am lost at wiring
Old 06-26-2013, 10:31 PM
Boosted Firehawk's Avatar
Where u at in illinos?
Old 06-26-2013, 10:39 PM
stuntinZ28's Avatar
Montgomery IL right outside of aurora
Old 06-26-2013, 10:43 PM
stuntinZ28's Avatar
page edited 4/30/2005
1993
Cavity Wire Color Description
A Red Generator feed to instrument cluster
B Tan Oil pressure feed to instrument cluster
C Brown Oil level feed to instrument cluster
E Gry (manual) clutch anticipate signal (V6 VIN S only)
F Gry Feed from fuel pump and fuel pump relay to prime connector
G Dk Green/White Vehicle speed signal
J Dk Green/White Fuel pump relay control
Text Box: ©shbox.com
K
Dk Green Coolant temperature feed to instrument cluster
1994
D Orange/Black Spark Retard Request
E Tan/Black Throttle Position Sensor Signal (EBTCM)
F Tan Serial data signal
H Dk Blue/White (Automatic) Performance switch signal
(Manual) Skip shift indicator control (V8 VIN P only)
K
1995
F Tan Serial data signal (VIN S only) see C105 for VIN P
K
Old 06-26-2013, 10:45 PM
stuntinZ28's Avatar
I am assuming D&E are 2 of the wires in plug c220
Old 06-26-2013, 10:54 PM
stuntinZ28's Avatar
A Purple Theft deterrent relay to starter solenoid feed
B Black/White Ground feed to fuel pump relay
C Orange Power feed from PCM BAT fuse to PCM
D
Grey Feed from fuel pump and fuel pump relay to prime connector
1995
C info not known
D
Old 06-26-2013, 10:55 PM
stuntinZ28's Avatar
and the 3rd wire would be C in plug C210
stuntinZ28's Avatar
now the real question would be do I need them,can I bypass them.......?
Quick Reply: engine wire harness HELP...
