Stock lt1 with mahle pistons??
Old 07-03-2013, 08:58 PM
Z28harcor's Avatar
Default Stock lt1 with mahle pistons??
I took my spare lt1 apart and on the back of the piston near the skirt it says mahle.. Did they Come stock with flattop mahle pistons?? 4 valve relief
Old 07-03-2013, 09:00 PM
jewbacca's Avatar
Not sure if they were produced by Mahle (someone with vastly more knowledge will probably chime in), but it could have been a rebuild.
Old 07-03-2013, 09:05 PM
englundjd's Avatar
iirc the LT1 had mahle hypertunic slugs in them from the factory
Old 07-03-2013, 09:29 PM
Z28harcor's Avatar
No ****.. I didn't know that.. Wonder why they did that.
Old 07-03-2013, 09:33 PM
Wicked 94TA's Avatar
I'm pretty sure the LT1 pistons were Mahles, I know the early ones were for sure. A friend of mine had a stock LT1 out of a '93 he torn down recently and they were Mahles, engraved right on the side of the piston.
Old 07-03-2013, 10:02 PM
shbox's Avatar
Because that is who they chose for the supplier. Why is it a head scratcher?
Old 07-03-2013, 10:35 PM
96capricemgr's Avatar
Mahle is a HUGE OEM supplier
Old 07-04-2013, 12:18 AM
jewbacca's Avatar
Learn something new everyday!
Old 07-04-2013, 02:25 AM
Z28harcor's Avatar
Never said it was a head scratcher? Why does everyone on this site act like a ******* wise guy?
Old 07-04-2013, 06:31 AM
leadfoot4's Avatar
Because in this particular case, many people, myself included, weren't aware that Mahle is a big OEM supplier. Most of us know of them due to their involvement in the high performance aftermarket, where cost is no object, and we also know that the GM "bean counters" usually keep a pretty tight grip on the purse strings. Therefore the surprise to find Mahle pistons in a high volume GM engine.
Old 07-04-2013, 08:03 AM
Pretty sure Mahle is the largest piston manufacturer in the world and provides the original pistons for a LOT of engines not just the LT1 and done so for a long time. Been common knowledge for a couple decades.
Old 07-04-2013, 08:32 AM
shbox's Avatar
Didn't you say "Wonder why they did that"? That's head scratching.
Gee, I thought what 96capricemgr said below. My question is why does everyone on this site have such a short fuse?
Old 07-04-2013, 12:37 PM
96lt1m6's Avatar
understanding the business end of it all GM contacted various piston manufacturers and accepted bids and proposals from all of them. GM wanted a durable,lightweight piston with tight tolerences to handle the higher rpm Lt1 and Mahle gave the best deal its not like they are Forged racing pistons.
Old 07-04-2013, 01:48 PM
KW Baraka's Avatar
Didn't you say "Wonder why they did that"? That's head scratching. ........
That's a fact!
KW
Old 07-08-2013, 08:10 AM
quik95lt1's Avatar
yup I was quite supprised my self about 8 years ago when I pulled my car apart when I bought it stock.....my motor was a GM replacement 4 bolt cause apparently somebody blew up the original and I figured the rebuilt motors only had mahles but turns out most had them right out of the factory in the 90's
Quick Reply: Stock lt1 with mahle pistons??
